MUM Europe 2020
infused
Trunking Vlans to VMWare (Block VLAN->VLAN traffic)
Sun Jan 13, 2013 8:53 am
Hi Guys,
I have a bridge for trunking, bri-trunk. I have added 5 vlans to the bridge to trunk to vmware. This works fine, however, I can access all vlans from all vlans. If that makes sense. How can I block traffic between vlans? Is there a better way to do this?
samsung172
Re: Trunking Vlans to VMWare (Block VLAN->VLAN traffic)
Sun Jan 13, 2013 8:47 pm
It make sense if you put vlans to a bridge. Then you bridge the vlans together. Put vlan to the Interface pointing to vmware. Not to a bridge. And tag in vmware.
infused
Sun Jan 13, 2013 9:11 pm
If you put vlans to the interface, you get the same behavior.
samsung172
Sun Jan 13, 2013 9:14 pm
then you somhow bridge them in Vmware switch etc.
samsung172
Sun Jan 13, 2013 9:15 pm
Btw, its also possible that you have a route between Your vlan's, and that the traffic are routed.
infused
Mon Jan 14, 2013 3:19 am
Correct. When added to bridge or ethernet port, they are routed. That's what I am trying to stop.
rjickity
Mon Jan 14, 2013 3:25 am
You must add a firewall filter on the forward chain to that interface to stop your traffic then
Sent from my GT-I9100 using Tapatalk
infused
Mon Jan 14, 2013 7:53 am
So what's the easiest rule to add then?
I have 3 vlans.
Lets just say vlaid 1001,1002,1003
1001: 10.1.1.1/24
1002: 10.1.2.1/24
1003: 10.1.3.1/24
Is there a simple rule I can add to each to ensure that they cannot communicate with each other. I plan to have a lot of vlans,
CelticComms
Mon Jan 14, 2013 4:44 pm
The router will route (forward) all traffic unless you stop it in the forwarding filters.
You can start with a simple rule in the forwarding chain with action=drop. Then add rules above it with action="accept" for any traffic that you actually want to forward.
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
infused
Mon Jan 14, 2013 8:26 pm
Yes. Do you have an example based on my info above?
zyflex
Thu Jan 24, 2013 9:06 pm
Try this in ip firewall filter:
chain=forward action=drop in-interface=VLAN1001 out-interface=!ether1-gateway
Then the traffic on VLAN1001 is only allowed to access your ether1 port.
samsung172
Tue Jan 29, 2013 1:17 am
No. You get the same behavior at l3 (routed) but you dont bridge the vlans together (l2)
Eg, when you put vlans to bridge, you will find all the other units's mac addresses. If you put to a Interface, you will not. ITs also possible to to a lot bad stuf, when put all vlan to one bridge. Then its no reasion to use the vlan's. Better to just add all ip to the Interface.
che
Tue Jan 29, 2013 3:17 am
Hi Guys,
Have you tried adding VLANs on the bridge interface, not as bridge port, and bridging physical interfaces? That way you will keep VLAN isolation as you intended and their availability on all physical interfaces you added to the bridge.
CelticComms
Tue Jan 29, 2013 3:37 am
Go into /IP Firewall and add a filter in the forwarding chain with nothing selected except Action=Drop.
At that point no traffic will be routed between interfaces at level 3. You may then want to add specific rules *above* that "drop all" rule with specific traffic that *is* to be forwarded - e.g. by specifying specific interfaces, IP ranges etc.
Users browsing this forum: anav, reynolds087 and 56 guests
