MUM Europe 2020
spike15mk
Problem installing MikroTik 5.22 on Dell PowerEdge R210 II
Tue Jan 22, 2013 3:18 pm
Heloo,
I am trying to install MikroTik 5.22 on brand new Dell PowerEdge R210 II. The problem is that MikroTik does not recognize the HDD. The setting in bios is AHCI mode, there is no option to change it to SATA, ATA etc. Is there solution to my problem, or any advice that could help me.
TnX
CelticComms
Re: Problem installing MikroTik 5.22 on Dell PowerEdge R210
Tue Jan 22, 2013 6:20 pm
Can you describe that part of the BIOS settings? I thought I had configured one of those to ATA mode.
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
spike15mk
Tue Jan 22, 2013 6:35 pm
Thank you for your replay. There is "SATA Settings". Inside there is "Embedded SATA"(my mistake on the first post, later i found there is ATA and RAID settings), but still I cant install MiktoTik 5.22. MikroTik cannot find the HDD.
spike15mk
Mon Jan 28, 2013 5:35 pm
Just to update the topic, I tried with demo version of MikroTik 5.6 and 5.11 and still no luck. Now I am planning to remove one hdd put on a desktop machine, install RouterOS and then return back to R210 II.
Lakis
Forum Veteran
Forum Veteran
Mon Jan 28, 2013 8:12 pm
Send email to support see if controller is supported with detail description of ur PC
U can try installing on USB - if BIOS support boot from USB
spike15mk
Tue Jan 29, 2013 1:26 am
Thank you for your replay. Is there any difference between CD and USB install(for the controller support) ??
Lakis
Forum Veteran
Forum Veteran
Tue Jan 29, 2013 1:35 am
No no spike15mk
I wrote install on USB not from USB
spike15mk
Tue Jan 29, 2013 1:39 am
No no spike15mk
Sorry my mistake. Well I will wrote an email to support, and tomorrow I will remove one hdd and install MikroTik on desktop PC, then I will put it back in server(hopefully it will work). But I will not have raid this way...I am out of options
mankomal
Tue Jan 29, 2013 9:59 am
No no spike15mk
Spike15mk ,
I was getting similar problems you could change HDD setting from AHCI to IDE and check again if it works for you. I was able to solve my problem like that
spike15mk
Tue Jan 29, 2013 11:45 am
No no spike15mk
Spike15mk ,
Mankomal,
Unfortunately there is no IDE settings in Dell PowerEdge R210 II. There is AHCI, ATA and RAID.
mankomal
Tue Jan 29, 2013 11:57 am
Spike,
I am trying to replicate your problem at my end ... you can add me on skype my id is singh.mankomal
I got this working 3 days back only on one of my servers with similar problems
deejayq
Wed Jan 30, 2013 12:18 pm
i think ATA and IDE are the same thing
spike15mk
Wed Jan 30, 2013 1:16 pm
I think so to. I read somewhere that is possible to remove SAS controller card and install then...
spike15mk
Wed Jan 30, 2013 4:18 pm
Spike,
Mankomal,
There is a 6 people on Skype with name like yours. Can you please add me. My name is bogdan.jeliskoski on Skype.
tnX
danielillu
Thu Jan 31, 2013 1:33 am
As far as I know there is no RAID support in RouterOS.
The name you are looking for your SATA Setting is "ATA", which you indicated your Dell R210ii has.
if you absolutely need a RAID setup there is an overkill but effective solution:
- you can install RouterOS inside an VMWare ESXi hypervisor, which can be installed (and monitor) in RAID environments.
Hope it helps!
Lakis
Forum Veteran
Forum Veteran
Thu Jan 31, 2013 1:49 am
spike15mk cant find ur email
I dont want to expose this but anyway
make contact with this company -overnet com mk- I think u live in same area
maybe they can help u with that
spike15mk
Thu Jan 31, 2013 2:03 pm
Thank you for the hint. I will check them today if I make the time :)
Users browsing this forum: inteq and 51 guests
