MUM Europe 2020
plisken
2 isp to 1 lan
Fri Jan 25, 2013 12:01 am
I have a router board 2011UAS-2HnD
wan1 eth10 = dhcp client default route distance = 2 eth9 =
wan2 eth9 =dhcp client default route distance = 1
eth1 = Lan 192.168.100.0/24 I would that if wan1 fails wan2 come to work.
how can wan2 see that when wan1 failt wan2 take over the job?
I try this but it's not working
http://wiki.mikrotik.com/wiki/Load_Bala ... e_Gateways
like to advice
CelticComms
Re: 2 isp to 1 lan
Fri Jan 25, 2013 12:31 am
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
plisken
Re: 2 isp to 1 lan
Fri Jan 25, 2013 10:03 am
See this good to you?
[admin@MikroTik] /ip> route
[admin@MikroTik] /ip route> add dst-address=206.190.36.45 gateway=192.168.0.219
[admin@MikroTik] /ip route> add dst-address=206.190.36.45 gateway=10.98.247.145
[admin@MikroTik] /ip route> add distance=1 gateway=192.168.0.219 routing-mark=isp1
[admin@MikroTik] /ip route> add distance=1 gateway=192.168.0.219 routing-mark=isp1 check-gateway=ping
[admin@MikroTik] /ip route> add distance=1 gateway=10.98.247.145 routing-mark=isp2 check-gateway=ping
[admin@MikroTik] /ip route> add distance=1 gateway=10.98.1.1 routing-mark=isp2 check-gateway=ping
[admin@MikroTik] /ip route> add distance=2 gateway=206.190.36.45 routing-mark=isp2 check-gateway=ping
[admin@MikroTik] /ip route> add dst-address=85.234.197.5 gateway=192.168.0.219 scope=10
[admin@MikroTik] /ip route> add dst-address=10.98.212.10 gateway=10.98.247.145 scope=10
[admin@MikroTik] /ip route> add dst-address=10.1.1.1 gateway=206.190.36.45 scope=10 target-scope=10 check-gateway=ping
[admin@MikroTik] /ip route> add dst-address=10.1.1.1 gateway=85.234.197.5 scope=10 target-scope=10 check-gateway=ping
[admin@MikroTik] /ip route> add dst-address=10.2.2.2. gateway=10.98.1.1 scope=10 target-scope=10 check-gateway=ping
value of dst-address must contain '/'
[admin@MikroTik] /ip route> add dst-address=10.2.2.2 gateway=10.98.1.1 scope=10 target-scope=10 check-gateway=ping
[admin@MikroTik] /ip route> add dst-address=10.2.2.2 gateway=10.98.212.10 scope=10 target-scope=10 check-gateway=ping
[admin@MikroTik] /ip route> add distance=1 gateway=10.1.1.1 routing-mark=isp1
[admin@MikroTik] /ip route> add distance=1 gateway=10.2.2.2 routing-mark=isp1
[admin@MikroTik] /ip route> add distance=1 gateway=10.2.2.2 routing-mark=isp2
[admin@MikroTik] /ip route> add distance=1 gateway=10.1.1.1 routing-mark=isp2
[admin@MikroTik] /ip route> add dst-address=206.190.36.45 type=blackhole distance20
expected end of command (line 1 column 46)
[admin@MikroTik] /ip route> add dst-address=206.190.36.45 type=blackhole distance=20
[admin@MikroTik] /ip route> add dst-address=10.98.1.1 type=blackhole distance=20
I don't understood the 10.1.1.1 and the 10.2.2.2 ip's
that really exist? should I set it somewhere
plisken
Re: 2 isp to 1 lan
Sun Jan 27, 2013 10:41 am
It does not work,
What am I doing wrong
If both isp's online = internet reachable
If isp1 is down = internet unreachable
After reboot router is isp2 reachable
Nat rules
[admin@MikroTik] /ip firewall nat> print detail
0 chain=srcnat action=masquerade src-address=192.168.100.0/24 out-interface=gw1
1 chain=srcnat action=masquerade src-address=192.168.100.0/24 out-interface=gw2
dhcp-client
[admin@MikroTik] /ip dhcp-client> print detail
0 interface=gw1 add-default-route=yes default-route-distance=1 use-peer-dns=yes use-peer-ntp=yes dhcp-options=hostname,clientid status=bound
address=192.168.0.233/24 gateway=192.168.0.1 dhcp-server=192.168.0.1 primary-dns=195.130.131.2 secondary-dns=195.130.130.130 expires-after=48m12s
1 interface=gw2 add-default-route=yes default-route-distance=2 use-peer-dns=yes use-peer-ntp=yes dhcp-options=hostname,clientid status=bound
address=10.98.247.148/28 gateway=10.98.247.145 dhcp-server=10.98.247.145 primary-dns=10.98.213.10 secondary-dns=10.98.88.1 primary-ntp=10.98.247.145
secondary-ntp=85.234.197.2 expires-after=23h39m37s
With isp1 down
[admin@MikroTik] /ip route> print detail
0 S dst-address=0.0.0.0/0 gateway=98.139.183.24
gateway-status=98.139.183.24 unreachable check-gateway=ping distance=1
scope=30 target-scope=10 routing-mark=isp1
1 S dst-address=0.0.0.0/0 gateway=173.194.65.94
gateway-status=173.194.65.94 unreachable check-gateway=ping distance=2
2 S dst-address=0.0.0.0/0 gateway=173.194.65.94
gateway-status=173.194.65.94 unreachable check-gateway=ping distance=1
scope=30 target-scope=10 routing-mark=isp2
3 S dst-address=0.0.0.0/0 gateway=98.139.183.24
gateway-status=98.139.183.24 unreachable check-gateway=ping distance=2
4 ADS dst-address=0.0.0.0/0 gateway=10.98.247.145
gateway-status=10.98.247.145 reachable via gw2 distance=2 scope=30
target-scope=10 vrf-interface=gw2
5 ADC dst-address=10.98.247.144/28 pref-src=10.98.247.148 gateway=gw2
gateway-status=gw2 reachable distance=0 scope=10
6 S dst-address=98.139.183.24/32 gateway=gw1 gateway-status=gw1 unreachable
distance=1 scope=10 target-scope=10
7 A SB dst-address=98.139.183.24/32 type=blackhole distance=20
8 A S dst-address=173.194.65.94/32 gateway=gw2 gateway-status=gw2 reachable
9 SB dst-address=173.194.65.94/32 type=blackhole distance=20
10 ADC dst-address=192.168.100.0/24 pref-src=192.168.100.1 gateway=bridge-lan
gateway-status=bridge-lan reachable distance=0 scope=10
With isp1 and isp2 up
distance=1 scope=30 target-scope=10 routing-mark=isp1
distance=2 scope=30 target-scope=10 routing-mark=isp1
distance=1 scope=30 target-scope=10 routing-mark=isp2
distance=2 scope=30 target-scope=10 routing-mark=isp2
4 ADS dst-address=0.0.0.0/0 gateway=192.168.0.1
gateway-status=192.168.0.1 reachable via gw1 distance=1 scope=30
target-scope=10 vrf-interface=gw1
5 DS dst-address=0.0.0.0/0 gateway=10.98.247.145
6 ADC dst-address=10.98.247.144/28 pref-src=10.98.247.148 gateway=gw2
7 A S dst-address=98.139.183.24/32 gateway=gw1 gateway-status=gw1 reachable
8 SB dst-address=98.139.183.24/32 type=blackhole distance=20
9 A S dst-address=173.194.65.94/32 gateway=gw2 gateway-status=gw2 reachable
10 SB dst-address=173.194.65.94/32 type=blackhole distance=20
11 ADC dst-address=192.168.0.0/24 pref-src=192.168.0.233 gateway=gw1
gateway-status=gw1 reachable distance=0 scope=10
12 ADC dst-address=192.168.100.0/24 pref-src=192.168.100.1 gateway=bridge-lan
duxovni
Re: 2 isp to 1 lan
Sun Jan 27, 2013 10:43 am
It is an example
You should use yours
duxovni
Re: 2 isp to 1 lan
Sun Jan 27, 2013 11:23 am
its an example.
you should use your appropriate one
plisken
Re: 2 isp to 1 lan
Sun Jan 27, 2013 9:24 pm
I understand that this is as an example, but I don't know which ip range in to use. This Is the lan ip range?
Thanks for your reply
deejayq
Re: 2 isp to 1 lan
Wed Jan 30, 2013 12:32 pm
use two ip's that should never be offline, like google dns and opendns or something like it
if it's pingable you can use it
plisken
Re: 2 isp to 1 lan
Mon Feb 04, 2013 12:16 am
it still don't work
Users browsing this forum: pwrusrcom and 50 guests
