arxont
Loopback connector
Mon Mar 04, 2013 3:53 pm
Hello! Please tell me how to connect loopback connector (RJ45 1-3 & 2-6) to mikrotik?
shahbazian
Trainer
Trainer
Re: Loopback connector
Tue Mar 05, 2013 12:29 am
To use the loopback no need to use the Ethernet interface.
Just need to create a bridge on router without any bridgeport
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
arxont
Tue Mar 05, 2013 2:18 am
Thanks for the answer. I know about the bridge. I need just that - to physically up port
samsung172
Tue Mar 05, 2013 3:17 am
actually what you describe, is to connect a 100/10 connection without poe to mikrotik. this will make a port/interface active. as loopback, it would just connect to itself. You can use this port, to a lot of stuff. Loopback interface, internal, is one thing, but loopback in Ethernet is also possible. but why do you want to do this? If you want. you need to revert rj45 connection, so that RX and TX in both sides is the opposite. eg. 1-3 and 3-1 and 2-6 and 6-2)
If you buy a crossover cable, it will do the stuff 4 you.
Users browsing this forum: No registered users and 43 guests
