HaPe
Exchange marks of packets betwean two routers
Sat May 18, 2013 7:13 pm
Is it possible to exchange marks of packets betwean two routers?
lordkappa
Re: Exchange marks of packets betwean two routers
Sat May 18, 2013 8:30 pm
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Mangle
No. As per the documentation, they are only used internally.
CelticComms
Sat May 18, 2013 8:53 pm
Not directly, but you may be able to achieve the same result in a different way. For example, if the routers are connected via a common layer 2 network you might be able to use different VLANs to carry distinct traffic then re-mark the packets at the far end.
HaPe
Sat May 18, 2013 8:57 pm
Thank you for a reply. I'll do it using vlans.
bawolek
Mon May 20, 2013 8:32 pm
you can use Diffserv/TOS also ;p
Users browsing this forum: Amazon [Bot], LeoNaXe and 38 guests
