guy
PPPoE Noob
Thu May 23, 2013 7:45 pm
Hi all,
I am trying an x86 box with 6.0rc13 with a Draytek 120 adsl modem.
It kind of works, but i only seem to be able to browse google! I can open the google page, search for e.g. speedtest.net or bbc.co.uk and bring up the search results and advertising content, but when i click a link or type a URL directly into the address bar i get nothing. I even resolved some websites to IP's and punch the ip's into the address bar, and tried in firefox as well is IE - no change.
The same laptop works on a different wired and wireless network so i don't think it is the laptop.
I am using Google's dns 8.8.8.8 so thought perhaps this was a problem and tried an ISP dns server, but that made no difference.
What have i done??
I presume its got to be something to do with the routing or NAT/firewall?
here is my config - I have a dhcp client set on my PPPoE client picking up my single static IP. At the bottom of the config i have included the contents of the routing table.
I can ping/resolve any website i like, but i can only browse google and search, if i click any links, nothing happens.
thanks for any help i'm sure i'm just being stupid..
# may/23/2013 17:06:19 by RouterOS 6.0rc13# software id = S90M-F92F
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether2 keepalive-timeout=\
disabled name=pppoe-out1 password=password use-peer-dns=yes user=\
username@internet.com
add name=dhcp-pool-1 ranges=192.168.9.1-192.168.9.253
add address-pool=dhcp-pool-1 disabled=no interface=ether1 name=dhcp1
/port
set 0 name=serial0
add address=192.168.9.254/24 comment="added by setup" interface=ether1 network=\
192.168.9.0
add address=192.168.9.0/24 comment="added by setup" dns-server=8.8.8.8 gateway=\
192.168.9.254
set allow-remote-requests=yes
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=\
192.168.9.0/24
[admin@MikroTik] >
Also, dynamic routes:
0 ADS 0.0.0.0/0 89.145.254.70 11 ADC 89.145.254.70/32 11.11.11.248 pppoe-out1
02 ADC 192.168.9.0/24 192.168.9.254 ether1
0
GhostWorks
Re: PPPoE Noob
Sat May 25, 2013 9:24 pm
I'm trying to setup my CCR1036-12G-4S with the same adsl modem ( Draytek Vigor120) but my issue is worse
Interface ....
PPPoE interface > Ethernet1
Ethernet1 > ADSL Ethernet modem
Ethernet4 > 192.168.1.1 ( DHCP : Yes ) LAN
utilizing tools > ping and ping 8.8.8.8 via PPoE interface works, however trying to ping same address via Ethernet1 failed.
Plus from ethernet4 can access Draytek Vigor120 WebGUI
Same I'm a PPPoE Noob as well ...lol
guy
Re: PPPoE Noob
Tue May 28, 2013 6:33 pm
lol everyone has to start as a noob :-(
I see you already got sorted in another post :-)
anyone else got any ideas on my issue?
thanks
nickshore
Re: PPPoE Noob
Tue May 28, 2013 7:18 pm
Can you turn off Add Default Gateway on your dhcp client, and turn on Add Default Gateway on your pppoe-client ?
Then see if it works
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
guy
Re: PPPoE Noob
Wed May 29, 2013 1:10 pm
Thanks for the reply Nick,
I checked the Add default gateway settings, turns out I actually had my dhcp client unconfigured. I re set it up and it doesn't get an ip address.
the add default gateway setting was already enabled on the pppoe interface.
Its bizarre, like I say I can ping anything by name and resolve and reply ok, just can't browse.
I know my laptop is ok but I will try another just to rule it out!
guy
Re: PPPoE Noob
Wed May 29, 2013 3:55 pm
just for further info, I just made sure that I was able to connect using the same pppoe connection, using the same laptop and the same draytek 120 modem and it worked fine when using the PPPoE client in windows.
I wiresharked the traffic and I could see data passing to and from the laptop and web servers but nothing in any browser..
(Edited for clarity..)
Users browsing this forum: No registered users and 27 guests
