MUM Europe 2020
maxwellnina
pppoe over vlan
Mon Jun 17, 2013 10:59 pm
Hi All
sorry to bother but I came to you all to see if I can have this headache solve
in fact i have on my core system a pppoe server and a core switch where i can handle remote bridge access and pppoe access
through 2 vlans as you can see on the png attached
[img]
[/img]
so I'm sending the vlans over wireless bridges (till here no problem)
but while in client side i always waste to equipments (RB750) one to manage vlans and the second one to pppoe access( vlan 50)
so I usualy the RB750 this way
add l2mtu=1590 name=bridge-trunk
add bridge=bridge-trunk interface=ether1
/interface vlan
add interface=bridge-trunk l2mtu=1586 name=vlan50 vlan-id=50
add interface=bridge-trunk l2mtu=1586 name=vlan111 vlan-id=111
add l2mtu=1590 name=bridge-access50
add l2mtu=1590 name=bridge-access111
/interface bridge port add bridge=bridge-access50 interface=vlan50
/interface bridge port add bridge=bridge-access50 interface=ether2
/interface bridge port add bridge=bridge-access111 interface=vlan111
/interface bridge port add bridge=bridge-access111 interface=ether5
and the come up on ether2 with a cable to connect RB751U-2Hnd
to configure the pppoe access for the client
/interface pppoe-client add user=georges password=georgesjungle interface=ether1 add-default-route=yes use-peer-dns=yes disabled=no
Now I'm looking the way to use only one equipment (RB751) at client side
so a kind of pppoe over trunk unfortunately I tried many scenario without success
for example add pppoe client directly on bridge-trunk
/interface pppoe-client add user=georges password=georgesjungle interface=bridge-trunk add-default-route=yes use-peer-dns=yes disabled=no
Please can some of you give me some hint to solve it ??
rjickity
Re: pppoe over vlan
Tue Jun 18, 2013 3:48 am
you should be able to simply create the vlan interface on ether1 (that goes to the AP) and then create pppoe client on the vlan interface. Then on ether 2 create the LAN. or you could create a bridge and add ether2 and the wlan1 if you want to provide local wifi also.
Users browsing this forum: No registered users and 41 guests
