gorkems
how i connecting to ubnt devices behind hotspot
Sun Jun 23, 2013 9:39 pm
i have two network on mikrotik . one of is hotspot 11.0.0.0/24 ( port 2 and 3 ) second network is from dhcp server 192.168.11.0/24 ( port 3-4 )
my ubnt devices is behind the hotspot port 2 . Devices ips are 192.168.11.XXX .( static i give them this ips )
i want to connect them from second network ( port 3-4 ) but i cant do that ... What i do
pls help me
thanks for help advence
SurferTim
Re: how i connecting to ubnt devices behind hotspot
Sun Jun 23, 2013 11:03 pm
You must bypass the device ips that are behind the hotspot.
/ip hotspot ip-binding
add address=11.0.0.xxx type=bypassed
gorkems
Sun Jun 23, 2013 11:28 pm
not working ... i still cant connect them with 192.168.11.0/24 network ... Is it necessary to make changes on the firewall?
SurferTim
Sun Jun 23, 2013 11:34 pm
Is there a reason you selected the 11.0.0.x network for a localnet? That is not a localnet ip range. I would have used 10.0.0.x/24.
Check "/ip hotspot hosts" to insure you are using the correct ip. Maybe the hotspot NAT is translating them to different ip addresses. Insure the "to-address" is the same as the "address" for those devices. The "to-address" is the ip the router sees.
Besides that, yes, you need to insure your firewall doesn't block anything.
gorkems
Sun Jun 23, 2013 11:45 pm
i upload a image of my host section ... thanks for your help but i do it what you say but i cant connect
SurferTim
Sun Jun 23, 2013 11:53 pm
It is the to-address the router sees. Try connecting to one of those ips. Try bypassing and connecting to 11.0.0.240. That should be the device 192.168.1.50.
The problem is the router does not know where the 192.168.1.x network is. If you look in "/ip route", you will probably not find a route for 192.168.1.x, so it will use the default gateway route.
You might be able to assign a vlan on that interface, but I think you must disable the hotspot 1:1 NAT to do that.
/ip hotspot
set 0 address-pool=none
gorkems
Mon Jun 24, 2013 12:18 am
yes when i connect 11.0.0.x i connected the device ... but how i use their org. ips i dont know how i make 1 1 nat or make vlan
can you help me
thanks
SurferTim
Mon Jun 24, 2013 1:35 am
I assign static ips in the range of the hotspot interface. I set my dhcp servers to leave a few ips for this kind of thing.
I would assign 10.0.0.1/24 to the router hotspot interface, then set the dhcp server to issue 10.0.0.16 to 10.0.0.254.
Assign each ubnt device an ip between 10.0.0.2 and 10.0.0.15 and bypass those ips.
Then disable the hotspot NAT so they are not translated.
kraker
Mon Jul 08, 2013 10:23 am
you should use management vlan to connect ubnt device behind the hotspot....
PeterDoBrasil
Sat Mar 12, 2016 4:50 pm
Iám only using mac to Bypass!!
Users browsing this forum: Bing [Bot] and 25 guests
