It is not really wrong. Maybe we're both right 50%
Maybe it is best to block both ways. Block initiated connection from both inside and outside.
Hi, you only need to make a address-list containing the folowing addresses:
(taken from http://www.whatsapp.com/cidr.txt)
31.13.69.240/32
31.13.70.49/32
31.13.71.49/32
31.13.73.49/32
31.13.74.49/32
31.13.76.81/32
31.13.77.49/32
50.22.75.192/27
50.22.93.192/27
50.22.198.204/30
50.22.210.32/30
50.22.210.128/27
50.22.225.64/27
50.22.235.248/30
50.22.240.160/27
50.23.90.128/27
50.97.57.128/27
75.126.39.32/27
108.168.174.0/27
108.168.176.192/26
108.168.177.0/27
108.168.180.96/27
108.168.254.65/32
108.168.255.224/32
108.168.255.227/32
158.85.0.96/27
158.85.5.192/27
158.85.46.128/27
158.85.48.224/27
158.85.58.0/25
158.85.61.192/27
158.85.224.160/27
158.85.233.32/27
158.85.249.128/27
158.85.249.224/27
158.85.254.64/27
169.53.29.128/27
169.53.250.128/26
169.54.2.160/27
169.54.210.0/27
169.54.222.128/27
173.192.162.32/27
173.192.219.128/27
173.192.222.160/27
173.192.231.32/27
173.193.205.0/27
173.193.230.96/27
173.193.230.128/27
173.193.230.192/27
173.193.239.0/27
174.36.208.128/27
174.36.210.32/27
174.36.251.192/27
174.37.199.192/27
174.37.217.64/27
174.37.231.64/27
174.37.243.64/27
174.37.251.0/27
184.173.73.176/28
184.173.136.64/27
184.173.147.32/27
184.173.161.64/32
184.173.161.160/27
184.173.173.116/32
184.173.179.32/27
184.173.195.32/27
184.173.201.32/27
184.173.204.32/27
192.155.212.192/27
198.11.193.182/31
198.11.212.0/27
198.11.217.192/27
198.11.251.32/27
198.23.80.0/27
198.23.86.224/27
198.23.87.64/27
208.43.115.192/27
208.43.117.79/32
208.43.117.136/32
208.43.122.128/27
2607:f0d0:1b01:d4::/64
2607:f0d0:3004:136::/64
2607:f0d0:3005:183::/64
2607:f0d0:3006:84::/64
2607:f0d0:3006:af::/64
Hard mode: Try using the packet sniffer on the router to find how whatsapp communicates and then block it with the firewall.
I haven't used the packet sniffer on RouterOS, but looking at it quickly, I would set whatsapp up on a control device and then filter the packet sniffer on the interface you're connecting to and the MAC address of your control device.
When you're sniffing, start sending messages and making calls etc etc. That should give you enough information to block it through the firewall.
all consumers - connect to DNS-resolved resources.means no need to turn DSL into bridge mode.? then how filters will be applied on users direct connected to NAT ports of DSL router.
# Copy and Paste the above to WinBox New Terminal #
/system scheduler
add comment="Whatsapp Blocker" interval=2m name="Whatsapp Blocker" on-event="#\
\_Use DNS Entrys and add Address to the Firewall Address-list #\r\
\n:foreach i in=[/ip dns cache all find where (name~\"whatsapp\") && (type\
=\"A\") ] do={\r\
\n :local tmpAddress [/ip dns cache get \$i address];\r\
\ndelay delay-time=10ms\r\
\n# prevent script from using all cpu time #\r\
\n :if ( [/ip firewall address-list find where address=\$tmpAddress] = \
\"\") do={ \r\
\n :local cacheName [/ip dns cache get \$i name] ;\r\
\n :log info (\"added entry: \$cacheName \$tmpAddress\");\r\
\n /ip firewall address-list add address=\$tmpAddress list=Whatsapp co\
mment=\$cacheName;\r\
\n}\r\
\n}" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive \
start-time=startup
/ip firewall filter add chain=forward action=drop dst-address-list=Whatsapp disabled=no comment="Whatsapp Blocker"
Whats difference between interval 2 myes, interval 2 minutes
From Whatsapp cidr...are you tried this all ip range ?Hi, you only need to make a address-list containing the folowing addresses:
31.13.69.240/32
31.13.70.49/32
31.13.71.49/32
31.13.73.49/32
31.13.74.49/32
31.13.76.81/32
31.13.77.49/32
50.22.75.192/27
50.22.93.192/27
50.22.198.204/30
50.22.210.32/30
50.22.210.128/27
50.22.225.64/27
50.22.235.248/30
50.22.240.160/27
50.23.90.128/27
50.97.57.128/27
75.126.39.32/27
108.168.174.0/27
108.168.176.192/26
108.168.177.0/27
108.168.180.96/27
108.168.254.65/32
108.168.255.224/32
108.168.255.227/32
158.85.0.96/27
158.85.5.192/27
158.85.46.128/27
158.85.48.224/27
158.85.58.0/25
158.85.61.192/27
158.85.224.160/27
158.85.233.32/27
158.85.249.128/27
158.85.249.224/27
158.85.254.64/27
169.53.29.128/27
169.53.250.128/26
169.54.2.160/27
169.54.210.0/27
169.54.222.128/27
173.192.162.32/27
173.192.219.128/27
173.192.222.160/27
173.192.231.32/27
173.193.205.0/27
173.193.230.96/27
173.193.230.128/27
173.193.230.192/27
173.193.239.0/27
174.36.208.128/27
174.36.210.32/27
174.36.251.192/27
174.37.199.192/27
174.37.217.64/27
174.37.231.64/27
174.37.243.64/27
174.37.251.0/27
184.173.73.176/28
184.173.136.64/27
184.173.147.32/27
184.173.161.64/32
184.173.161.160/27
184.173.173.116/32
184.173.179.32/27
184.173.195.32/27
184.173.201.32/27
184.173.204.32/27
192.155.212.192/27
198.11.193.182/31
198.11.212.0/27
198.11.217.192/27
198.11.251.32/27
198.23.80.0/27
198.23.86.224/27
198.23.87.64/27
208.43.115.192/27
208.43.117.79/32
208.43.117.136/32
208.43.122.128/27
blocked whatsapp or working ?
OkFrom Whatsapp cidr...are you tried this all ip range ?Hi, you only need to make a address-list containing the folowing addresses:
31.13.69.240/32
31.13.70.49/32
31.13.71.49/32
31.13.73.49/32
31.13.74.49/32
31.13.76.81/32
31.13.77.49/32
50.22.75.192/27
50.22.93.192/27
50.22.198.204/30
50.22.210.32/30
50.22.210.128/27
50.22.225.64/27
50.22.235.248/30
50.22.240.160/27
50.23.90.128/27
50.97.57.128/27
75.126.39.32/27
108.168.174.0/27
108.168.176.192/26
108.168.177.0/27
108.168.180.96/27
108.168.254.65/32
108.168.255.224/32
108.168.255.227/32
158.85.0.96/27
158.85.5.192/27
158.85.46.128/27
158.85.48.224/27
158.85.58.0/25
158.85.61.192/27
158.85.224.160/27
158.85.233.32/27
158.85.249.128/27
158.85.249.224/27
158.85.254.64/27
169.53.29.128/27
169.53.250.128/26
169.54.2.160/27
169.54.210.0/27
169.54.222.128/27
173.192.162.32/27
173.192.219.128/27
173.192.222.160/27
173.192.231.32/27
173.193.205.0/27
173.193.230.96/27
173.193.230.128/27
173.193.230.192/27
173.193.239.0/27
174.36.208.128/27
174.36.210.32/27
174.36.251.192/27
174.37.199.192/27
174.37.217.64/27
174.37.231.64/27
174.37.243.64/27
174.37.251.0/27
184.173.73.176/28
184.173.136.64/27
184.173.147.32/27
184.173.161.64/32
184.173.161.160/27
184.173.173.116/32
184.173.179.32/27
184.173.195.32/27
184.173.201.32/27
184.173.204.32/27
192.155.212.192/27
198.11.193.182/31
198.11.212.0/27
198.11.217.192/27
198.11.251.32/27
198.23.80.0/27
198.23.86.224/27
198.23.87.64/27
208.43.115.192/27
208.43.117.79/32
208.43.117.136/32
208.43.122.128/27
Always works, both to QoS or block it
Cheers.
