Sigma721
Internet speed test
Fri Aug 02, 2013 10:34 pm
Hi everyone
I would like to be able to test my internet speed(ADSL connection) from my RB. Is there a way to do this without using a 2nd RB or PC? So is there like a Google server or something you can run a test to?
Also which is better TCP or UDP?
Many thanks
IPANetEngineer
Trainer
Trainer
Re: Internet speed test
Sat Aug 03, 2013 1:41 am
speedtest.net or speedtest.comcast.net.
Most DSL providers have their own speedtest page
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Sigma721
Sat Aug 03, 2013 7:40 pm
Thanks, but how do I run a test to speedtest.net? When I try put www.speedtest.net in the "test to" box in winbox, it says cant connect. I have also tried the sites ip.
Ehman
Fri Sep 13, 2013 3:25 am
Thanks, but how do I run a test to speedtest.net? When I try put http://www.speedtest.net in the "test to" box in winbox, it says cant connect. I have also tried the sites ip.
Hmmmmm....I'm also looking for this feature, the reason behind it is ...I want to build a intelligent loadbalancer that can fine tune the scale of 50/50 on 2 lines to other % by testing the line speed of each line and then applying the % so that 100% of the total capacity can be distributed to all users. can be useful is so many ways, another reason is, if you have a up to 7meg line and a up to 2meg line, then it can super fine tune itself.
class889
Fri Sep 13, 2013 7:42 pm
you can use the tool Fetch
>tool fetch
and after that u need to write the URL of the file u wanna download, find a link from your isp and try to download it using the router.
Users browsing this forum: No registered users and 32 guests
