nirmal
Uploading the supout.rif file
Fri Aug 23, 2013 7:38 am
I have configuration backup with in the file name of supout.rif - i would like restore this file into the new mikrotik router
how to do that?
ivtts
Re: Uploading the supout.rif file
Mon Aug 26, 2013 10:32 pm
supout.rif is a binary file and (i suppose) not designed for restore (it designed for treatment in support). However you may view his content by uploading that on mikrotik.com into your account (you need register).
For backup/restore you must use these Winbox commands: Files->Backup and Files->Restore. You can drag'drop these files with Explorer. These files also are binary.
Another way is using console commands (in "New Terminal" in Winbox, or in connection via telnet or ssh) export and import.
E.g., export your current config to file backup_at_20130816.conf
ros code
/export file=backup_at_20130816.conf
That file appear in "Files" window of Winbox. Then you can restore this config on other devices:
ros code
/import file=backup_at_20130816.conf
These files are plain text, so you can download it on PC, edit, and then use for configure devices.
Users browsing this forum: cedie, Matthewlaverty and 33 guests
