MUM Europe 2020
warlock
Access servers on a specific port
Thu Oct 10, 2013 6:52 pm
Hello everyone,
I have a problem that I am not able to solve.
It is about 2 subnet masks which should communicate together on certain ports.
Eth2 - clients 192.168.0.0/24
Eth3 - servers 10.80.50.0/29
 0   chain=input action=accept protocol=tcp src-address=192.168.0.0/24
     in-interface=eth2 dst-port=8291
1   chain=forward action=accept protocol=tcp src-address=10.80.50.0/29
     dst-address=192.168.0.0/24,
 2   chain=forward action=accept protocol=tcp src-address=192.168.0.0/24
     dst-address=10.80.50.0/29
 3   chain=forward action=drop
 4   chain=input action=reject reject-with=icmp-protocol-unreachable
     protocol=icmp
 5   chain=input action=drop
The above rule is working ok. But, the problem is when i wont to specify on wich port they should comunicate only.
     dst-address=192.168.0.0/24 dst-port=135,136,137,
     dst-address=10.80.50.0/29 dst-port=135,136,137,
     protocol=icmp
Cannot access at all.
warlock
Re: Access servers on a specific port
Fri Oct 11, 2013 11:15 am
Bump.
Here is another example.
Clients from eth2 192.168.0.0/24 need to access file server on eth1 10.80.50.4/29
 1   chain=forward action=accept protocol=tcp src-address=10.80.50.4
     dst-address=10.80.50.4 dst-port=135,136,137,
     protocol=icmp
Cannot access.
     protocol=icmp
But this work.
deejayq
Fri Oct 11, 2013 6:54 pm
maybe you should torch to see what ports are being used.
maybe you are blocking some ports.
as far as i've read on the internet, the netbios uses broadcast packets, maybe it has something to do with that.
warlock
Fri Oct 11, 2013 8:58 pm
Hmmm.. i used connection filter to check on which ports they communicate and i readed manuel for ports that need to be open.
It seems that work only when i check "Any. Port: " in firewall filter option and adding ports there.
Confusing i must tell, by the way does anyone know what Any. Port: mean, i readed somewhere on the internet but is a litle bit confused for me, my english is not so good.
Continueing to wok under this seting i tested windows rdp as an example. I needed to apply on both rule rule for rdp port in order to work but i just wonned to access from one subnet, dont understand why on both rule i must to add this port and to use Any. Port:?
Any help will,would be appreciated for this "anomaly" and making this correct.
warlock
Sat Oct 12, 2013 8:48 pm
Bump.
warlock
Sun Oct 13, 2013 10:17 pm
I google half internet for this and cannot find solution.
Bump. Sory guys i realy need help about this. :?
efaden
Sun Oct 13, 2013 10:42 pm
Post your full export compact and what you are trying to do. I'll look at it tonight.
Sent from my SCH-I545 using Tapatalk
CelticComms
Mon Oct 14, 2013 12:50 am
You really need to use Torch to see which ports are involved. Also note that while some NetBIOS traffic does indeed use the same port on the client and server many protocols do not do that. If your clients always initiate connections you may want to try allowing NEW connections to a restricted IP/port range on the server subnet but allow all ESTABLISHED & RELATED traffic in the other direction.
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
warlock
Mon Oct 14, 2013 1:20 am
Hi efaden, thanks for help, please read last couple of posts.Its simple, yet strange.. :?
warlock
Mon Oct 14, 2013 1:22 am
Trust me mate i know wich are the ports, the problem is mikrotik (firewall rules) or am i dumb to configure this rules properly thats why i need help. :?
efaden
Mon Oct 14, 2013 1:23 am
I am pretty sure that looking at the above ruleset his problem is that he has no rules with the src-port as 135,136,137 and they aren't getting picked up by connection tracking....
Op: What is on these ports? And post your whole config... export compact.
warlock
Mon Oct 14, 2013 1:27 am
On these ports is comunication for windows network. I tried src-port dont work. it only work when is Any. Port: even then i must on both rule to add ports that i wont to open. Confusing.
There is no more configuration except this and default rules for ip address mate.
efaden
Mon Oct 14, 2013 1:29 am
I trust that there is nothing else... but I just find it easier to see your export... if you want me to look through it post the whole export compact. I have time tonight to figure it out.
Also windows stuff uses 135, 137, 138, 139...
http://en.wikipedia.org/wiki/List_of_TC ... rt_numbers
warlock
Mon Oct 14, 2013 1:35 am
1. config in first and other posts, its a default configuration with only these rules above and example when its work and when its not working.
2. i know, i posts that in last post.
efaden
Mon Oct 14, 2013 1:54 am
How are you testing that it is or isn't working?
efaden
Mon Oct 14, 2013 2:36 am
I'm pretty sure you need... All four of these.
dst-address=192.168.0.0/24 src-port=135,136,137,
dst-address=10.80.50.4 src-port=135,136,137,
warlock
Mon Oct 14, 2013 10:57 am
That will not work.
The problem is that when a client make a season on that port with server, user use some other port on his side, and when you apply reverse rule server also use another port on his side beside that 135,136,137 etc.
An when rules above or mine apply then they block other ports on they side. got it mate ? :idea:
Confusing for makin rule with minimum acces. :?
CelticComms
Mon Oct 14, 2013 1:59 pm
That will not work.
Which is why you use the ESTABLISHED and RELATED connection states to permit the return traffic to the client as I mentioned earlier.
1) Apply rules to permit the new connections from the client to the server on the known ports.
2) Apply rules to permit the ESTABLISHED and RELATED traffic between the client and server.
warlock
Mon Oct 14, 2013 2:08 pm
Oh,
quick from the head...
ip firewall rule chain forward connection state established action accept
ip firewall rule chain forward connection state releated action accept
Am i correct ?
CelticComms
Mon Oct 14, 2013 2:59 pm
Oh,
Am i correct ?
Yes - with whatever other selectors are appropriate given the security requirements - e.g. src/dst addresses/address ranges.
warlock
Mon Oct 14, 2013 10:15 pm
Oh,
Am i correct ?
Works like a charm. Karma is on the way.
By the way, do you know maybe what this option is for: Any. Port:
CelticComms
Mon Oct 14, 2013 11:19 pm
It matches on the port regardless of whether it is the dst. or src. port.
Users browsing this forum: chuckt, danirpg, mbovenka, MSN [Bot], Technetium and 50 guests
