tloosle
quickset
Thu Oct 10, 2013 11:56 pm
On the batch of RB2011UAS-2HND-IN quickset is missing? is there a way to enable it?
janisk
Re: quickset
Fri Oct 11, 2013 12:50 pm
what RouterOS version you are running?
tloosle
Re: quickset
Fri Oct 11, 2013 5:50 pm
I had to enable wireless in the packages. After that the quickset showed up.
Before I didn't have to do that.
rayman1366
Re: quickset
Sun Oct 13, 2013 2:49 pm
use latest routeros
tloosle
Re: quickset
Mon Oct 14, 2013 6:26 pm
router os 6.4 made no difference.
Solution: enable the wireless package.
Seems its not enabled by default anymore.
t
silversword
Re: quickset
Tue Oct 22, 2013 5:48 pm
Had same issue with wireless not showing up had to enable.
V6.5 Issue with quick Set.
New RB2011UAS-2HnD out of the box. Upgraded 6.1 to 6.5 RouterOS.
Quickset in AP mode
Under LAN/WLAN section says DHCP Server is unchecked however from a default config DHCP is enabled
Quickset doesn't show correct information?
Users browsing this forum: No registered users and 44 guests
