MUM Europe 2020
niren
Should I need RouterOS
Tue Oct 15, 2013 9:50 am
I am using Mikrotik RouterBoard 750 GL.
I want to configure my Gateway(Router) for security management, Should I use RouterOS for my requirement or can it be done by winbox.
If it is done by Winbox then what is the purpose of RouterOS.
Basically my question is I guess I can use winbox to access Mikrotik router configuration so that I can achieve IDS/IPS, monitor IPs, IPsec and more, then why should I use RouterOS?
deejayq
Re: Should I need RouterOS
Fri Oct 18, 2013 12:35 pm
RouterOS, as it's name says it's the Operating System of the router you're using.
you may be referring to something else.
niren
Fri Oct 18, 2013 4:31 pm
If that is the case why there is a link http://www.mikrotik-routeros.net/install.aspx says I can install RouterOS separately to access Router configuration, So Installed RouterOS(separately in PC) and RB750GL would be act as single router, doesn't it?. Correct me If I wrong.
Things I have already: RouterBoard 750GL, Working LAN setup for every system in my office, Winbox to manage configuration.
Since I have read that winbox, webFig, telnet, ect are not secure to manage router, I had to go for RouterOS. If RouterOS(separately in PC) is not need for my requirement please let me know.
efaden
Fri Oct 18, 2013 8:23 pm
Because you can ALSO run it on a computer and use it as a router there.... but Deejayg is correct. RouterOS is the operating system that runs on the router. You can use Winbox, WebFig, SSH, Telnet, etc to configure it. SSH is secure, Winbox has a secure mode, and WebFig can be made secure. I'd read the actual mikrotik Wiki instead of the page you referenced. wiki.mikrotik.com
-Eric
Users browsing this forum: bogdan, jaceqp123, lokz, MCPC10, negr0, TomaszF and 61 guests
