suntan
pppoe-client and nat rule problem
Fri Oct 18, 2013 12:05 pm
Hi All,
Strange problem I have been having for months now, running an RB951G-2HnD attached to a TPLINK ADSL modem. Using pppoe client on router. Running wireless network and rest of ports bridged. All runs fine except when PPP connection drops for whatever reason I have to manually bring it back up by ssh'ing in and running the following commands to firstly bring up the ppp interface and then change the out-interface back to pppoe-out1 as it reverts to ether1-gateway when the PPP connection drops.
I have had a look around this forum but can't find anyone with this exact problem. No doubt a configuration issue and an error on my part but could someone point me in the direction of a solution? This "fix" isn't exactly wife friendly and when the connection drops she can't fix when I'm away!
Tried setting a static default route in case that was it but it had no effect. The only line in the logs relating to the PPP connection being dropped is something about
 pppoe-out1: terminating.. - administrator request
I certainly didn't request it to drop :)
[admin@MikroTik] /interface pppoe-client> print
 0 X  name="pppoe-out1" max-mtu=1480 max-mru=1480 mrru=disabled interface=ether1-gateway user="****" password="****"
      profile=default keepalive-timeout=60 service-name="" ac-name="" add-default-route=yes default-route-distance=1 dial-on-demand=yes
      use-peer-dns=yes allow=pap,chap,mschap1,mschap2
[admin@MikroTik] > /interface pppoe-client enable 0
[admin@MikroTik] > /ip firewall nat print
 0   ;;; default configuration
     chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=ether1-gateway
[admin@MikroTik] > /ip firewall nat set 0 out-interface=pppoe-out1
Thanks in advance.
suntan
RB951G2HnD
Re: pppoe-client and nat rule problem
Wed Oct 23, 2013 9:51 am
Hi Suntan,
You need to change your NAT rule this way:
remove 0
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=192.168.0.0/27 to-addresses=0.0.0.0
But don't forget to modify your src-address value.
Andrew
Andrew
suntan
Wed Oct 23, 2013 10:18 am
Thanks Andrew, I will give that a go and see how I get on and report back.
EDIT: All has been fine since doing as you suggested, many thanks.
suntan
Users browsing this forum: EdPa, erlinden, leonardogyn, MSN [Bot] and 103 guests
