niren
Ping outside LAN not working with Mikrotik router
Tue Oct 22, 2013 3:04 pm
I try to ping outside internet from Mikrotik terminal but I can't. I tried to ping gmail.com IP as
gmail.com IP is: 74.125.236.53
> ping 74.125.236.53
output:
timout
But If I ping my local system I can able to do as
> ping xxx.xxx.xxx.206
output:
connected
Why can not I able to ping outside my LAN connection?
deejayq
Re: Ping outside LAN not working with Mikrotik router
Wed Oct 23, 2013 1:50 pm
your ISP may be blocking ICMP
niren
Wed Oct 23, 2013 6:13 pm
I have contact my Internet Service provider about this issue, they told me this is problem with mikrotik router and they don't have enough experience with Mikrotik router, they couldn't help me.
c0d3rSh3ll
Long time Member
Long time Member
Wed Oct 23, 2013 6:51 pm
Check your filter rules and if you have a default gateway for the router
nothing
niren
Thu Oct 24, 2013 8:51 am
I don't have any filter and NAT rules. What else I need to check?
Rudios
Forum Veteran
Forum Veteran
Thu Oct 24, 2013 11:19 pm
Maybe is not having a NAT rule the issue.
Hoe are you connected to the internet and how is your IP setup?
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
niren
Sat Oct 26, 2013 10:32 am
ether1-Input:
Address = 10.0.0.2/30 Network= 10.0.0.0
ether2-LAN:
Address = 121.222.121.193/28 Network = 121.222.121.192
IPs specified are not correct. I pick some random number.
Rudios
Forum Veteran
Forum Veteran
Sat Oct 26, 2013 7:46 pm
What routes do you have?
SurferTim
Sat Oct 26, 2013 8:08 pm
If you do not have any NAT rules, you won't go far from home. You should probably have at least this:
add chain=srcnat action=masquerade out-interface=ether1
If ether1 is not your WAN interface, change that.
Users browsing this forum: No registered users and 47 guests
