MUM Europe 2020
dancho
Ubiquiti behind Mikrotik
Tue Dec 10, 2013 12:29 am
here is the deal.
NSM5---NSM5__Omnitik__SXT---SXT__RB1100ahx2(pppoe server)__SXT---SXT__Omnitik__NSM5---SXT
everything is in singe bridge with IP 172.16.16.1/22
from first NSM5 I can access every mikrotik in this configuration but can not access any NS after that RB1100ahx2. I can ping them tho but can not open with browser. What am I missing? I've read there is something with NAT? Can you please tell me what to do?
plisken
Re: Ubiquiti behind Mikrotik
Tue Dec 10, 2013 3:03 pm
Describe the situation better or make a drawing,
what will you do
Have you logged in with https on the ubiquiti's
dancho
Wed Dec 11, 2013 9:14 pm
http://picpaste.com/pics/Untitled-0LKQd ... 794923.png
I can access everything that is green.
I can not access everything that is red.
I can ping everything on that picture from my NS5.
Anything else you need?
troy
Wed Dec 11, 2013 9:41 pm
Green? Red? where... I don't see a picture.
You say you can ping... what size packets? Try a 1500 byte packet and see what happens... my guess is that you have an MTU issue somewhere along the way, most likely with one of the UBNT devices, which is limited to 1500 bytes out of the box. Raise the MTU to 1600, and you should be good to go.
Good luck!
dancho
Wed Dec 11, 2013 10:52 pm
Good luck!
now? can you see it?
I can access first nanostation but not last. both nanostations same config. and yes MTU is set to 1500. it is default.
troy
Wed Dec 11, 2013 11:26 pm
heh.. yeah, I see it now. It does indeed smack of an MTU problem. Ping with full sized packets and figure out which devices will need some extra room.
dancho
Mon Dec 16, 2013 4:38 pm
news on this.
I just saw that in the picture that I've already posted I can access all those mikrotiks because I was opening them via MAC. Now if I try to open them via IP I got the following:
I can ping everything with full sized packets.
dancho
Thu Dec 19, 2013 5:12 am
bump
deejayq
Tue Dec 24, 2013 1:07 pm
if you connect to the rb1100 can you ping from it the sxt connected in port 3?
Petzl
Fri Dec 27, 2013 11:31 am
We use WDS mode for ubiquity, if you do client and ap mode , the device wil do some sort of Natting ...
dancho
Sun Dec 29, 2013 10:23 pm
deejayq: yes I can ping any IP on the network.
Petzl: we are using WDS too.
plisken
Sun Dec 29, 2013 10:37 pm
Have you try with https ?
dancho
Sun Dec 29, 2013 10:53 pm
tried with enabled https and with disabled https on ubiquiti devices. no luck
plisken
Sun Dec 29, 2013 11:06 pm
Are you sure about your subnet?
First say you:everything is in singe bridge with IP 172.16.16.1/22
Later speak you from everything is in single bridge with IP 172.16.16.1/24
Maby a mistake in subnets in the devices
dancho
Tue Dec 31, 2013 2:57 am
sorry about that. it is /22 but even if it was /24 it should not be a problem. and even I made somewhere mistake and put 24 instead of 22 it should work. I guess... :S
Users browsing this forum: No registered users and 47 guests
