MUM Europe 2020
yamenh
prevent users using the network to transfer files
Wed Jan 08, 2014 11:46 pm
Hi!
I have a Mikrotik server cloud and many users connected using wireless APs on the server to use the internet, using hotspot.
the problem is the performance of the network sometimes get down and I think it is because the users are using the network to play games or transfer files.
how to prevent the users from transferring files or playing games through the network and letting them just use it as an internet connection
thanks
Lakis
Forum Veteran
Forum Veteran
Re: prevent users using the network to transfer files
Thu Jan 09, 2014 1:08 am
U can disable FTP 21 port
disable default forward on wlan
disable file and print sharing ports 137, 138, 139 and 445
etc etc
yamenh
Thu Jan 09, 2014 8:57 pm
THANKS FOR REPLY
but what is etc etc
and id I disable the FTP port would it affect the download from the internet or not?
deejayq
Fri Jan 10, 2014 10:04 am
here's what i would do
ip firewall filter add chain=forward action=drop src-address=192.168.x.x protocol=tcp connection-bytes=504857-0
ip firewall filter add chain=forward action=drop src-address=192.168.x.x protocol=udp connection-bytes=504857-0
ip firewall filter add chain=forward action=drop dst-address=192.168.x.x protocol=tcp connection-bytes=504857-0
ip firewall filter add chain=forward action=drop dst-address=192.168.x.x protocol=udp connection-bytes=504857-0
this will break any large file download and game
Users browsing this forum: nowinskit, Paul9cf22ad1 and 53 guests
