ialcantara
how to route specific traffic directly to the WAN bypass VPN
Sun Jan 12, 2014 4:32 am
I have a established a PPTP VPN for all outgoing traffic this is the configuration I used for NAT and Mangle http://www.strongvpn.com/setup_mikrotik_pptp.shtml , but I need some traffic to be routed outside the VPN direcly from the WAN , like sling box and USTVNOW servers because this streaming services work better with out the over head of the VPN. how can I do that? I think I can identify the IP addresses that this servers use to connect, I guess I only need to understand the rules that will apply to bypass the VPN.
thank you very much.
Ivan
c0d3rSh3ll
Long time Member
Long time Member
Re: how to route specific traffic directly to the WAN bypass
Sun Jan 12, 2014 5:38 am
First add a mangle rule in the top of your rules like this
/ip firewall mangle add chain=prerouting dst-address-list=bypassed action=accept
Then add the ip of the server in the bypassed address list in the address list tab.
Send from my mobile phone using Tapatalk.
ialcantara
Sun Jan 12, 2014 7:17 am
Thank you it worked, is there a way I can do it by hostname instead of by IP Address? thank you for your help by the way!.
Ivan.
c0d3rSh3ll
Long time Member
Long time Member
Sun Jan 12, 2014 5:47 pm
Ivan.
Is not possible but with script you can use hostname
http://wiki.mikrotik.com/wiki/Use_host_ ... wall_rules
Users browsing this forum: Bing [Bot], dj23, ismel0x, lostb1t, sch, ToTheFull and 49 guests
