MUM Europe 2020
kawsar
Disconnect always while i work remotely tomikrotik 1100ah
Tue Jan 14, 2014 8:27 am
Dear all,
I have two mikrotik 1100 ah router.. One of them is ok but other one has problem. while i work remotely it just disconnect always...pls tell me why?
plisken
Re: Disconnect always while i work remotely tomikrotik 1100a
Tue Jan 14, 2014 11:36 am
Have you login with the MAC or IP-adres
If you login with IP-adres from router try it with MAC
kawsar
Tue Jan 21, 2014 5:46 am
thanks for answer. but Its disconnect when i would like to support remotely by its public IP Address. What could be the solutions.
deejayq
Tue Jan 21, 2014 8:02 am
how do you connect to it? winbox or ssh? try both options
cbrown
Trainer
Trainer
Wed Jan 22, 2014 1:48 am
Is your bandwidth being used up? I have run into this when a sites bandwidth was being maxed out. If that's the problem a quick QoS will fix your problem.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
kawsar
Tue Sep 23, 2014 6:34 am
How to configure ssh?
Users browsing this forum: MSN [Bot] and 45 guests
