MUM Europe 2020
logg
load balancing problem
Thu Jan 16, 2014 12:41 pm
hi,
a week ago i bought a rb 751U-2HnD i neet to configure it for make a load balancing between 2 adsl.
i've this configuration
 0 X ;;; Load Balancing | NON TOCCARE |
     chain=srcnat action=masquerade out-interface=Wireless
 1   chain=srcnat action=masquerade out-interface=WAN2
 2   chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=WAN3
/ip firewall mangle
 0   chain=prerouting action=accept dst-address=192.168.2.0/24 in-interface=Local
 1   chain=prerouting action=accept dst-address=192.168.2.0/24
 2   chain=prerouting action=accept dst-address=192.168.3.0/24 in-interface=Local
 3   chain=prerouting action=accept dst-address=192.168.3.0/24
 4   chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes dst-address-type=!local in-interface=Local
     per-connection-classifier=both-addresses-and-ports:2/0
 5   chain=prerouting action=mark-connection new-connection-mark=WAN3_conn passthrough=yes dst-address-type=!local in-interface=Local
     per-connection-classifier=both-addresses-and-ports:2/1
 6   chain=prerouting action=mark-routing new-routing-mark=to_WAN3 passthrough=yes in-interface=Local connection-mark=WAN3_conn
 7   chain=input action=mark-connection new-connection-mark=WAN2_conn passthrough=yes in-interface=WAN2
 8   chain=input action=mark-connection new-connection-mark=WAN3_conn passthrough=yes in-interface=WAN3
 9   chain=prerouting action=mark-routing new-routing-mark=to_WAN2 passthrough=yes in-interface=Local connection-mark=WAN2_conn
10   chain=output action=mark-routing new-routing-mark=to_WAN2 passthrough=yes connection-mark=WAN2_conn
11   chain=output action=mark-routing new-routing-mark=to_WAN3 passthrough=yes connection-mark=WAN3_conn
0 A S  0.0.0.0/0                          192.168.2.1               1
 1 A S  0.0.0.0/0                          192.168.3.1               1
 2 X S  0.0.0.0/0                          192.168.1.1               1
 3 A S  0.0.0.0/0                          192.168.3.1               1
 4   S  0.0.0.0/0                          192.168.2.1               2
 5 X S  0.0.0.0/0                          192.168.1.1               1
 6 ADC  192.168.2.0/24     192.168.2.124   WAN2                      0
 7 ADC  192.168.3.0/24     192.168.3.125   WAN3                      0
 8 ADC  192.168.100.0/24   192.168.100.1   Local                     0
i've some problem:
-traffic balacing is not the same on two balancig,in wan2 i've 10 gbt traffic in wan3 only 400 mb
-when i try to open a page it go slowly like if load balancig lose time to Establish from wich wan request is to send
example
when i try to go on mikrotik site it lose 10 seconds to give me page, when i'm on mikrotik site ad visit the site speed is much more
-i can't work properly port forwarding on my dvr
when i try to connect on mydvr sometime go sometime no
this is my rule for it
7   chain=dstnat action=dst-nat to-addresses=192.168.100.6 to-ports=1025 protocol=tcp in-interface=!Local dst-port=1025
 8   chain=dstnat action=dst-nat to-addresses=192.168.100.6 to-ports=9001 protocol=tcp in-interface=!Local dst-port=9001
some body can help please.
tnks in addvance
karina
Re: load balancing problem
Fri Jan 17, 2014 5:20 pm
before anything those SRc NAT rules are not right
1.. is ok
2. is changing the source nat to 0.0.0.0. should be masquerade
logg
Sun Jan 19, 2014 1:29 pm
tnks for answer
can you tell me more pls
deejayq
Mon Jan 20, 2014 4:49 pm
your rules seem messed up
try the example here
http://wiki.mikrotik.com/wiki/Manual:PCC
Users browsing this forum: No registered users and 46 guests
