kostasthess
Flash 90~100% CPU
Mon Jan 20, 2014 9:31 pm
I dont know what is writing to flash and is going from 85% ~ 100% at 2 hours uptime .
Anyone else has the same problem ?
The problem has been found on 751G and 951G routers . About 10 of them need restart to fix .
Thanks.
Wireless is my life...
maximan
Trainer
Trainer
Re: Flash 90~100% CPU
Mon Jan 20, 2014 10:48 pm
i had the same issue and the mikrotik's support recomend me to upgrade to v6.7 and it will fix. I don't try yet because the router can be reboot. You can try it.
M.
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
kostasthess
Tue Jan 21, 2014 12:43 am
All my routers has been upgraded to the latest RouterOS version with latest Firmware .
I cant understand why that happend
jwelebd
Tue Mar 04, 2014 4:53 pm
I have same problem.
Does RB750 support 6.XX or it increase CPU usage?
I am using 10mbps bandwidth, client under 100 person,
usermanager, no web proxy.
falestiny
Tue Mar 04, 2014 7:35 pm
Thanks.
did you enable proxy option?
norpan
Wed Mar 05, 2014 12:01 am
I have got indications from support that it could be caused by to little free memory. How much free memory do you have when this happens?
normis
Wed Mar 05, 2014 8:14 am
Flash means writing to disk (or in this case, NAND). What processes are running? Have you configured logging to disk, graphing, proxy?
jwelebd
Wed Mar 05, 2014 2:03 pm
Hello
logging to disk not configured,
graphing yes but not stored on disk
proxy is not enabled but it shows running.
please check screenshot.
jwelebd
Wed Mar 05, 2014 2:04 pm
2 more attachment
Users browsing this forum: Baidu [Spider], dawe4444, Google [Bot] and 36 guests
