MUM Europe 2020
jt2048
CRS125 and SFP ports not working?
Sat Jan 25, 2014 12:23 am
V6.7 We've been totally unable to get 2 CSR125 (a 125-24G-2HnD-IN and a 125-24G-15-RM) to talk over their SFP interfaces. Auto negotiate fails. The transceivers and jumpers have been tested in a pair of RB2011 and found to work (auto negotiate works and we can pass traffic on a routed network btwn the 2 units).
Is there some sort of bug lurking under the surface here or are we doing something dumb?
JT
teddy
Re: CRS125 and SFP ports not working?
Wed Jan 29, 2014 8:21 pm
Acknowledged. I observed the same thing. 6.7. Also I have failures at load ports on the switch through the combined master-port.
becs
Thu Jan 30, 2014 9:49 am
RouterOS v6.8 contains SFP module compatibility improvements for CRS125. With v6.8 it should work the same way as RB2011.
markom
Thu Jan 30, 2014 10:38 am
Just one question. Is SFP standard that is globally accepted? Shouldn't all SFP modules work fine in any SFP compatible devices ?
normis
Thu Jan 30, 2014 11:46 am
Yes, but this doesn't rule out minor software bugs.
DDMan11
Tue Jan 06, 2015 3:22 am
Is this still an issue? And what is v6.8/6.7? I have a brand new CRS125 with v6.24 (most up to date version) and I've already returned one SFP module thinking it was defective. Now seeing this it might have been a software issue. I have a genuine Cisco module in there but it still isn't work. Are you guys going backwards in your versions?
Thanks in advance.
Users browsing this forum: che, erkexzcx, mkx, MsLrO and 44 guests
