Gabo
SFP-port mirroring CRS125-2G-1S-2HnD routeros 6.5
Sun Feb 02, 2014 11:46 am
Hello
I am RouterOS newbie. I tried to configure port mirror on CRS125-2G-1S-2HnD (QCA-8513L switch) so every ingress/egress packet of sfp1-gateway would be mirrored to ethernet port ether24-sfp-mirror. No success so far. I can not see any packets on ether24-sfp-mirror.
Does anybody have idea what I am missing/doing wrong here?
My configuration follows, settings I changed marked as **CHANGED**:
/interface ethernet switch print
                                 type: QCA-8513L
                          bridge-type: service-vlan-bridge
  drop-if-no-vlan-assignment-on-ports:
        drop-if-invalid-vlan-on-ports:
             invalid-vlan-lookup-mode: ivl
                    drop-invalid-vlan: no
      use-svid-in-one2one-vlan-lookup: no
      use-cvid-in-one2one-vlan-lookup: yes
                  mac-level-isolation: no
                 vlan-level-isolation: no
           ipv4-multicast-lookup-mode: dst-mac-and-vid-always
     override-existing-when-ufdb-full: no
                      unicast-fdb-age: 5m
               ingress-mirror0-enable: yes
                  igress-mirror0-port: cpu
               ingress-mirror0-format: modified
               ingress-mirror1-enable: yes
                  igress-mirror1-port: ether24-sfp-mirror **CHANGED**
               ingress-mirror1-format: analyzer-configured **CHANGED**
                 ingress-mirror-ratio: 1/1
                egress-mirror0-enable: yes
                  egress-mirror0-port: cpu
                egress-mirror0-format: modified
                egress-mirror1-enable: yes
                  egress-mirror1-port: ether24-sfp-mirror **CHANGED**
                egress-mirror1-format: analyzer-configured **CHANGED**
                  egress-mirror-ratio: 1/1
                egress-sampling-ratio: 1/1
                             fdb-uses: mirror0
                            vlan-uses: mirror0
    mirror-egress-if-ingress-mirrored: no
             mirror-tx-on-mirror-port: no
         mirrored-packet-qos-priority: 0
      mirrored-packet-drop-precedence: 0
       bypass-vlan-ingress-filter-for:
  bypass-l2-security-check-filter-for:
and
/interface ethernet switch port print
23   name=ether24-sfp-mirror **CHANGED** switch=switch1 ingress-service-tpid=0x88A8 ingress-customer-tpid=0x8100 egress-service-tpid=0x88A8
     egress-customer-tpid=0x8100 drmp=no jumbo-frames=no mac-based-vlan-translate=no allow-unicast-loopback=no
     allow-multicast-loopback=no drop-when-ufdb-entry-sa-drop=no isolation-profile=30 ingress-vlan-type=edge-port default-customer-pcp=0
     default-service-pcp=0 mac-based-service-vlan=disabled mac-based-customer-vlan=disabled pcp-propagation-for-initial-pcp=no
     filter-untagged-frame=no filter-priority-tagged-frame=no filter-tagged-frame=no egress-vlan-type=edge-port
     egress-vlan-lookup=according-to-egress-vlan-type egress-pcp-propagation=no egress-vlan-mode=unmodified mac-vlan-type=edge-port
     ingress-mirroring=no ingress-mirror-to=mirror0 ingress-mirroring-by-vlan=no egress-mirroring=no egress-mirror-to=mirror0
     ingress-sampling-mode=all-frames-without-mac-error ingress-sampling=no ingress-sampling-ratio=1/1 egress-sampling=no drop-count=0
     qos-resolution=pcp-based,pcp-based,pcp-based,pcp-based,pcp-based,pcp-based,pcp-based,pcp-based qos-change-dei=no qos-change-pcp=no
     qos-change-dscp=no qos-pcp-dei-map-drop-precedence=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
     qos-pcp-dei-map-dscp=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 qos-pcp-dei-map-dei=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
     qos-pcp-dei-map-pcp=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 qos-pcp-dei-map-priority=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
24   name=sfp1-gateway switch=switch1 ingress-service-tpid=0x88A8 ingress-customer-tpid=0x8100 egress-service-tpid=0x88A8
     ingress-mirroring=yes **CHANGED** ingress-mirror-to=mirror1 **CHANGED** ingress-mirroring-by-vlan=no egress-mirroring=yes **CHANGED** egress-mirror-to=mirror1 **CHANGED**
Users browsing this forum: No registered users and 39 guests
