gogusrl
Basic VLAN setup help
Mon Feb 10, 2014 9:01 pm
I have a RB2011iL-RM and I need help with this setup :
eth1 - wan
eth2 - VLAN10
eth3 - VLAN20
eth4 - VLAN30
eth5 - TRUNK (goes into a HP switch already setup)
eth6-10 - not used
I need all VLANs to have access to the internet but keep them separated.
efaden
Re: Basic VLAN setup help
Mon Feb 10, 2014 9:27 pm
eth1 - wan
eth2 - VLAN10
eth3 - VLAN20
eth4 - VLAN30
eth6-10 - not used
Are eth2, eth3, eth4 tagged traffic or access ports?
Basically what you will do is
ros code
add comment="VLAN 10 Bridge" l2mtu=1584 name=bridge-vlan10 protocol-mode=none
add comment="VLAN 20 Bridge" l2mtu=1584 name=bridge-vlan20 protocol-mode=none
add comment="VLAN 30 Bridge" l2mtu=1584 name=bridge-vlan30 protocol-mode=none
set [ find default-name=ether1 ] name=ether01-gateway
set [ find default-name=ether2 ] name=ether02-vlan10
set [ find default-name=ether3 ] master-port=none name=ether03-vlan20
set [ find default-name=ether4 ] master-port=none name=ether04-vlan30
set [ find default-name=ether5 ] master-port=none name=ether05-trunk
set [ find default-name=ether6 ] master-port=none name=ether06-slave-local disabled=yes
set [ find default-name=ether7 ] master-port=none name=ether07-slave-local disabled=yes
set [ find default-name=ether8 ] master-port=none name=ether08-slave-local disabled=yes
set [ find default-name=ether9 ] master-port=none name=ether09-slave-local disabled=yes
set [ find default-name=ether10 ] master-port=none name=ether10-slave-local disabled=yes
/interface vlan
add interface=ether5-trunk  name=vlan10-ether5-trunk vlan-id=10
add interface=ether5-trunk  name=vlan20-ether5-trunk vlan-id=20
add interface=ether5-trunk  name=vlan30-ether5-trunk vlan-id=30
add bridge=bridge-vlan10 interface=ether2-vlan10
add bridge=bridge-vlan10 interface=ether5-trunk
add bridge=bridge-vlan20 interface=ether3-vlan20
add bridge=bridge-vlan20 interface=ether5-trunk
add bridge=bridge-vlan30 interface=ether4-vlan30
add bridge=bridge-vlan30 interface=ether5-trunk
That gives you your three access ports and one trunk port. They all come back to bridge-vlan10, bridge-vlan20, and bridge-vlan30. This is also using the main CPU so you will take a performance hit. If you wanted to you "could" do this with the switch chip instead which would give you wirespeed... but it is a bit more confusing to setup.
Once all that is done assign your IPs to the bridges, setup DHCP, DNS, and whatever else you need. Then use the firewall to block traffic between the bridges.
Make sense?
-Eric
gogusrl
Mon Feb 10, 2014 10:12 pm
I'm ashamed to admit I don't know what an access port is.
Eth2/3/4 should be able to communicate with the devices connected to the HP switch on their respective VLANs.
edit : maybe it helps to provide a bigger picture of what i'm trying to achieve :
Eth2/3/4 are connected at 1gbps to some servers. The trunk from port 5 goes to the 1gbps trunk port on the switch. The rest of the switch is setup with ports 1-8 VLAN10, 9-16 VLAN20, 17-24 VLAN30.
For example the server from eth2 should be able to communicate with ports 9 to 16 from the switch.
efaden
Mon Feb 10, 2014 10:23 pm
Access Port = Untagged traffic... usually for PCs, etc..... things that don't understand VLANs
Trunk Port = Tagged Traffic Only ... used between managed devices.
Mixed Port = Untagged + Tagged
My guess would be you want what I did above... Ether2/3/4 are access ports for those vlans and ether5 is the trunk.
w0lt
Tue Feb 11, 2014 1:25 am
-Eric
Eric,
Could you take the time to show how to do it using the internal switch chip? I for one appreciate the performance hit using ROS.
Thanks in advance,
tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
efaden
Tue Feb 11, 2014 1:46 am
Lets try.... The switch chip config is a little confusing... but I "think" it would look like this...
ros code
set [ find default-name=ether2 ] name=ether02-master-local
set [ find default-name=ether3 ] master-port=ether02-master-local name=ether03-slave-local
set [ find default-name=ether4 ] master-port=ether02-master-local name=ether04-slave-local
set [ find default-name=ether5 ] master-port=ether02-master-local name=ether05-slave-local
/interface vlan
add interface=ether02-master-local name=vlan10-ether02-master-local vlan-id=10
add interface=ether02-master-local name=vlan20-ether02-master-local vlan-id=20
add interface=ether02-master-local name=vlan30-ether02-master-local vlan-id=30
add bridge=bridge-vlan10 interface=vlan10-ether02-master-local
add bridge=bridge-vlan20 interface=vlan20-ether02-master-local
add bridge=bridge-vlan30 interface=vlan30-ether02-master-local
set ether02-master-local vlan-mode=secure vlan-header=always-strip default-vlan-id=10
set ether03-slave-local vlan-mode=secure vlan-header=always-strip default-vlan-id=20
set ether04-slave-local vlan-mode=secure vlan-header=always-strip default-vlan-id=30
set ether05-slave-local vlan-mode=secure vlan-header=add-if-missing
set switch1-cpu vlan-mode=secure vlan-header=add-if-missing
add vlan-id=10 switch=switch1 ports=ether02-master-local,ether05-master-local,switch1-cpu
add vlan-id=20 switch=switch1 ports=ether03-master-local,ether05-master-local,switch1-cpu
add vlan-id=30 switch=switch1 ports=ether04-master-local,ether05-master-local,switch1-cpu
NOTE: This will drop ALL Untagged traffic.
See: http://wiki.mikrotik.com/wiki/Manual:Sw ... p_Features
This is basically http://wiki.mikrotik.com/wiki/Manual:Sw ... outerOS_v6 ... the trunk example except I extended it to use the switch1-cpu also which allows routeros (e.g. the CPU) to actually see the packets and allow you to route through to ether1 using nat or whatever.
You could actually even use the switch chip or bridge rules to block the intra-vlan traffic and it would be faster than the ip filter rules also. Switch chip would be the fastest... bridge second, and ip filter slowest.
tania
Sat Feb 15, 2014 7:03 am
KennyPowers
Tue May 05, 2015 6:31 pm
ros code
/interface vlan
Hi Guys,
Sorry for the hijack, I followed this for my 951G-2hng V6.28.
I only have 2 VLANS one for a private network and the other for a hotspot. I also have a WiFi VAP bridged to each VLAN
My issue is whenever I put this line in "set switch1-cpu vlan-mode=secure vlan-header=add-if-missing" I loose the wan port it won't obtain an address from the bridged cable modem.
Can anyone help or suggest another/better way to do this?
DeamonMV
Thu May 28, 2015 9:43 pm
Hi guys.
Can help me with setup vlan on mikrotik 5.26 installed on x86 with realtek RTL8111C.
I have problem with understanding how vlans need to setup on mikrotik.
I use schem:
Cloud is a interface of my PC and to PC connected the mikrotik.
my R2 router have swith module, which configured: port 1/0 as trunk(vlan20) and port 1/1 as access(vlan20).
On mikrotik config:
/interface vlan
add arp=enabled disabled=no interface=ether1 l2mtu=16379 mtu=1500 name=\
    ether1.20 use-service-tag=no vlan-id=20
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    disabled=no forward-delay=15s l2mtu=16379 max-message-age=20s mtu=1500 \
    name=br-vlan20 priority=0x8000 protocol-mode=none transmit-hold-count=6
add address=192.168.20.13/24 disabled=no interface=br-vlan20 network=\
    192.168.20.0
and port
Then i start ping from linux-microcore-1 PC in GNS3 and launch wireshark on my PC and i can see the pakets with tag
where 192.168.20.20 IP of linux-microcore-1
and 192.168.20.13 IP of br-vlan int. mikrotik
But if I start ping on mikrotik, no matter what of interface use ether1.20(vlan) br-vlan20 ether1 i dont see pakets with tag:
Users browsing this forum: Google [Bot] and 34 guests
