Krisken
Mikrotik + VoIP
Thu Feb 13, 2014 4:29 pm
Today, i've put a voip server on the network here (IP 10.0.0.10) but it seems that he can't connect to my VoIP provider (SIP).
At IP >> Firewall >> Connections i see as Src Address the IP and before that IP there is a "U", so i suppose that this is a part of the solution?
Can somebody take a look at this file and tell me what i'm doing wrong?
My export file : http://pastebin.com/jNmr8e6A
w0lt
Re: Mikrotik + VoIP
Thu Feb 13, 2014 5:37 pm
[quote
21./ip pool
22.add name="DHCP Lan" ranges=10.0.0.1-10.0.0.200
39./ip address
40.add address=10.0.0.1/24 interface="bridge1 - Bureau" network=10.0.0.0
][/quote]
Might start your pool from 10.0.0.2..
Just saying.. :-)
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
Krisken
Re: Mikrotik + VoIP
Thu Feb 13, 2014 11:23 pm
Woops :-) Thanks, i think i was a little too quick :-)
But ehm, what won't solve the initial problem:-)
pcunite
Forum Veteran
Forum Veteran
Re: Mikrotik + VoIP
Fri Feb 14, 2014 1:22 am
Make sure you have a proper firewall setup and read my VoIP QoS post.
PeterSullivan
Re: Mikrotik + VoIP
Fri Feb 14, 2014 11:45 am
VoIP setting might be main issue of this. check the VOIP setting again.
Krisken
Re: Mikrotik + VoIP
Mon Feb 17, 2014 10:10 am
Hi PeterSullivan, what do you mean with "check the VOIP setting again"?
The supplier of the voip system wants to have these ports open:
Udp 5060 -> 10.0.0.138:5060
Udp 49152 tot 53246 -> 10.0.0.138(49152 tot 53246)
Udp 5001 -> 10.0.0.138:5001
Tcp 2222 -> 10.0.0.138:2222
UDP 1194 -> 10.0.0.138:1194
Users browsing this forum: No registered users and 36 guests
