mark14
How to block and stop torrent download
Sat Feb 22, 2014 11:02 am
Please help me how to block torrent download
I put this to layer seven protocol
^.*(get|GET).+(torrent|thepiratebay|isohunt|entertane|demonoid|btjunkie|mininova|flixflux|torrentz|vertor|h33t|btscene|bitunity|bittoxic|thunderbytes|entertane|zoozle|vcdq|bitnova|bitsoup|meganova|fulldls|btbot|flixflux|seedpeer|extratorrent|fenopy|gpirate|commonbits).*$"
But I I've still seen some user keep on downloading in torrent
Best regard,
ka81
Re: How to block and stop torrent download
Sat Feb 22, 2014 6:42 pm
Hi. I'm a newbie and it's all very difficult to me.
Router - http://routerboard.com/RB2011UiAS-2HnD-IN
PC connected to router with cable to ETH5.
on PC installed latest http://www.utorrent.com/
uTorrent - Settings - Connection - Port - 25312
uTorrent - Settings - Remote - login: ka81 , pass - XXXXXX
here all the time it says No access. Reconnecting in xx secs.
Help me please to input all necessary ports and everything needed into router settings.
today it's so:
p.s. with tp-link 1043 - NO problem, everything is working!
plisken
Sat Feb 22, 2014 7:55 pm
You must install rule for DNS and for www
Try this in dutch but follow the printscreens a made
http://www.wirelessinfo.be/index.php/mi ... es/torrent
mark14
Sun Feb 23, 2014 9:57 am
My Friend,
I try and put this as you sad but when I try to open uTorrent
and start to down load its still running,
thank you
mark14
Sun Feb 23, 2014 10:02 am
please check if this is corrent
plisken
Sun Feb 23, 2014 10:45 am
I think that you can add other torrent sites on that regexp.
plisken
Sun Feb 23, 2014 11:05 am
I forgot something, look now on the website http://www.wirelessinfo.be/index.php/mi ... es/torrent
You must add filter rules.
Add this rules above all the other
This rules give a heavy CPU load
mark14
Sun Feb 23, 2014 3:55 pm
my friend
I did what you sad but I think nothings happened
can you check my firewall rules what comes first or last
that is ok
Im sorry im just new to this router no experience yet
by the way im using this to office LAN
Thnk you,,, :)
mark14
Sun Feb 23, 2014 4:00 pm
im using 4 wan load balancing this is correct because there is a selection on out interface "all Ethernet" but I made rule and add for but wan 1 and wan 2
plisken
Sun Feb 23, 2014 5:59 pm
This looks good to me, thanks for given my karma
BWS001
Sun Feb 23, 2014 6:24 pm
The code provided looks like you are blocking the download of the .torrent file.. But if it comes from other sources or comes from a different kind of feed (other than HTTP) the torrent will still run. I would think if you truly want to stop the torrents from running you need to shape at layer 7
http://wiki.mikrotik.com/wiki/Basic_tra ... _protocols
cicserver
Mon Feb 24, 2014 6:57 am
I tried this [copied from http://aacable.wordpress.com blog and at last, it worked fine for me]
/ip firewall layer7-protocol
add comment="P2P WWW web base cnoetent Matching / Zaib" name=p2p_www regexp=\
"^.*(get|GET).+(torrent|thepiratebay|isohunt|entertane|demonoid|btjunkie|mininova|flixflux|vertor|h33t|zoozle|bitnova|bitsoup|meganova|fulldls|btbot|fenopy|gpirate|commonbits).*\$"
add comment="P2P DNS Matching / Zaib" name=p2p_dns regexp=\
"^.+(torrent|thepiratebay|isohunt|entertane|demonoid|btjunkie|mininova|flixflux|vertor|h33t|zoozle|bitnova|bitsoup|meganova|fulldls|btbot|fenopy|gpirate|commonbits).*\$"
/ip firewall mangle
add action=mark-packet chain=postrouting comment="p2p download" disabled=no layer7-protocol=p2p_www new-packet-mark="p2p download" passthrough=no
add action=mark-packet chain=postrouting disabled=no layer7-protocol=p2p_dns new-packet-mark="p2p download" passthrough=no
add action=drop chain=forward comment="Block P2p_www Packets / Zaib" disabled=no layer7-protocol=p2p_www
add action=drop chain=forward comment="Block P2p_dns Packets / Zaib" disabled=no layer7-protocol=p2p_dns
add action=drop chain=forward comment="Block General P2P Connections , default mikrotik p2p colelction / zaib" disabled=no p2p=all-p2p
mark14
Tue Feb 25, 2014 9:57 am
where would I put this code can you give me detailed instruction on how to apply this code
I so sorry I don't even had experience in handling mokrotic product or any other manageable router or switch
thank you
plisken
Tue Feb 25, 2014 10:44 am
This code must stand in regexp.
It's the same code as I you showed
teknofu
Mon Dec 15, 2014 7:50 am
It has been a while since this thread has been active but I figure I saw something that I could answer so why not.
As for the code from cicserver and how to "import" it into your router I would look at this article. http://wiki.mikrotik.com/wiki/Manual:Co ... tem_Backup
Specifically sections 4 and 5.
basically copy the text into a notepad file then save it as name.rsc instead of name.txt and then drag and drop into the files section on your router. Once you have that done, open a new terminal and type
import file=name.rsc
and the config will be placed in the proper sections of the router. Make sure you customize ip addresses and interface names or the command will fail.
Good luck in your future routing.
karina
Tue Dec 16, 2014 2:48 am
or simply copy and paste into a terminal window in the router
Users browsing this forum: laku and 65 guests
