MUM Europe 2020
alexburke
How to disable Quick Set in Webfig?
Sun Feb 23, 2014 10:36 pm
Hello!
How can I entirely disable the Quick Set page in Webfig once things are set up?
Thanks!
normis
Re: How to disable Quick Set in Webfig?
Mon Feb 24, 2014 11:05 am
Using the Design Skin button, it is possible to disable menus.
alexburke
Mon Feb 24, 2014 7:10 pm
Fair enough, thanks!
rpz
Fri Jan 02, 2015 11:13 pm
Thanks for that!
Problem remains when it comes to WinBox. How to disable "Quick Set" there?
jarda
Sat Jan 03, 2015 12:51 am
Impossible.
I would like to have a separate package called "quickset" to be able not to install it.
Users browsing this forum: No registered users and 40 guests
