obadaabdullah
no direct to login page
Tue Mar 11, 2014 4:54 pm
hello all
i have RB 951 V6.9
i set up every thing (addresses , dhcp , hotspot , ....)
i have a problem , when my hotspot users type any web site in their browsers they cant see my hotspot login page , but it work good if i type the ip of my hotspot interface.
any help please
SurferTim
Re: no direct to login page
Wed Mar 12, 2014 1:29 pm
Is the RB951 connected to the internet? Do you have valid dns servers entered in "/ip dns"? Did you set "allow-remote-requests=yes" there also?
If all the answers are yes, then post "/ip hotspot profile".
obadaabdullah
Thu Mar 13, 2014 10:41 am
yeh i'v done them all
/ip hotspot profile
set [ find default=yes ] html-directory=orbit-final
add dns-name=www.orbit.com hotspot-address=192.168.1.1 html-directory=\
orbit-final http-cookie-lifetime=1h name=hsprof1
add dns-name=www.orbit.com hotspot-address=192.168.2.1 html-directory=\
orbit-final http-cookie-lifetime=1h name=hsprof2
add dns-name=www.orbit.com hotspot-address=192.168.5.1 html-directory=\
orbit-final name=hsprof3
add dns-name=www.orbit.com hotspot-address=192.168.3.1 name=hsprof4
add dns-name=www.orbit.com hotspot-address=192.168.4.1 name=hsprof5
/ip hotspot
add address-pool=hs-pool-2 addresses-per-mac=1 disabled=no idle-timeout=10m \
interface=out1 name=hotspot1 profile=hsprof1
add address-pool=hs-pool-6 addresses-per-mac=1 disabled=no interface=out2 \
name=hs-out2 profile=hsprof2
add address-pool=dhcp_pool17 disabled=no interface="out wi fi" name=\
"hs-out wi fi" profile=hsprof3
add address-pool=hs-pool-3 disabled=no interface=out3 name=hs-out3 profile=\
hsprof4
add address-pool=dhcp_pool19 disabled=no interface=out4 name=hs-out4 profile=\
hsprof5
SurferTim
Thu Mar 13, 2014 1:20 pm
I think it is your entry for "dns-name=www.orbit.com". That domain name must resolve to your router's hotspot interface ip. That doesn't.
www.orbit.com resolves to 217.13.58.88
obadaabdullah
Fri Mar 14, 2014 7:51 pm
http://www.orbit.com resolves to 217.13.58.88
thanks
i think when my hotspot users connect to my network before entering their username and password and they try to open any web site they must direct to my log in page.
this domain(www.orbit.com) is local and it's working good with me
i have this problem with other domain on another server
SurferTim
Fri Mar 14, 2014 11:00 pm
I know how they work. The dns-name must resolve to the router's hotspot ip.
this domain(http://www.orbit.com) is local and it's working good with me
You own the domain orbit.com? www.orbit.com resolves to all these ips?
192.168.1.1
192.168.2.1
192.168.3.1
192.168.4.1
192.168.5.1
Somehow I doubt that.
If you are having problems with another domain on another server, then why did you post this stuff?
obadaabdullah
Sat Mar 15, 2014 1:47 am
i know you know....
You own the domain orbit.com? http://www.orbit.com resolves to all these ips?
192.168.1.1
192.168.2.1
192.168.3.1
192.168.4.1
192.168.5.1
i don't say i own this domain, i said it's local it's my network hotspot DNS name
it's work good on my network but i was working on another hotspot on another server and i made all the configuration as in my server hotspot, the problem is in the new one.
any way thank u i made it up , i downgrade from 6.9 to 6.7 and it's working good with the new one, i don't know how but it's working.
thanks again friend
SurferTim
Sat Mar 15, 2014 3:19 am
I tested your setup with ROS v6.9 on a localnet router ip of 192.168.1.1/24. Mine fails if I use "dns-name=www.orbit.com", or any domain that does not resolve to 192.168.1.1. No login page.
That dns-name must resolve to the ip of the hotspot interface ip. You can set that domain to resolve to that ip in "/ip dns static", but you lose the ability to go to that domain from the hotspot interface.
I guess now you can't upgrade to a newer ROS version without your hotspot failing. Oh well...
Users browsing this forum: atakacs, Bing [Bot], dzint, ebash43, invert, jasons6930, void2412 and 36 guests
