j7n
High CPU usage of Winbox on RB2011
Thu Mar 13, 2014 5:06 pm
I have purchased an RB2011 and upgraded RouterOS to v6.10 yesterday. It came with v6.5.
I am observing high CPU usage when Winbox is open and the router is practically idle (6 interfaces are up, no traffic). CPU load is 60-70 percent. When Winbox is closed, the Touchscreen reports 8-10 percent load.
http://dl.dropboxusercontent.com/u/6170 ... -usage.png
I am reading here that higher CPU usage is expected. However, opening Winbox on RB532 with even more windows twice, over both IP and MAC, causes about 5 to 10% CPU load there.
jaykay2342
Location: /Vigor/LocalGroup/Milky Way/Earth/Europe/Germany
Re: High CPU usage of Winbox on RB2011
Fri Mar 14, 2014 11:07 am
as i'm a linux guy i'm not using winbox at all, am i the only who just use ssh and web?
but have you checked what is eating the cpu cycles with the profile tool?
9-5 Job: Securityanalyst at a major MSSP.
Free time volunteer: Networkadmin and founder at a small non-profit WISP.
Certifications: ITILv3, GCIA
normis
Fri Mar 14, 2014 11:10 am
Open Tool->Profile to check what exactly eats the CPU.
j7n
Fri Mar 14, 2014 5:58 pm
I did not know about the Profile tool.
The category is unclassified. Now that I can look closer, if I create a 100 MBit connection, the percentage under 'unclassified' goes down, allowing the data transfer to take place normally. Then it rises again.
j7n
Sat Mar 15, 2014 2:57 pm
I have solved this problem. The CPU usage was caused by an open System -> RouterBoard window, which opened by default after upgrade and reboot, and was hidden behind other windows. After closing it, CPU load is at 10% now.
jaykay2342
Sat Mar 15, 2014 6:15 pm
I'm wondering why this can cause so much cpu usage. mikrotik? is this maybe a bug?
ariosvelez
Fri Jan 20, 2017 11:53 pm
Any recomendation when the usage comes from DNS??????? It jump all the time to 80% just on DNS
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
MTCNA, MTCRE, MTCINE
jarda
Wed Mar 22, 2017 7:41 am
Because of your bad firewall... Search for dns amplification attack and do not forget to drop all unwanted connections from wan port...
Users browsing this forum: No registered users and 30 guests
