kneuzgi
open firewall port
Mon Mar 17, 2014 4:50 pm
Hi
I'm a newbie with the routerOS software.
I'd like to open upd port 500 and 4500 for an internal ip addresse (e.g. 192.168.88.113)
Traffic should go in both direction! means internal to external and external to internal
How can I do that via Webinterface?
What do I have to enter where?
Thank you very much
ronybaalbaky
Re: open firewall port
Mon Mar 17, 2014 6:03 pm
please explain more , do you want to do port forwarding you mean ?
kneuzgi
Tue Mar 18, 2014 1:35 pm
I'd like to open the two udp ports (500 and 4500) so that traffic can be allowed.
Allow traffic from internal to external over UDP Port and also from external to internal
Rudios
Forum Veteran
Forum Veteran
Tue Mar 18, 2014 1:45 pm
It depends on your config but I assume you are using a 'default' SOHO config.
If so you are NAT-ting from your local LAN to the outside.
Only thing you need to do is create a NAT rule and a firewall filter allowance rule for each port
ros code
add chain=dstnat action=dst-nat in-interface=<your WAN interface> protocol=udp dst-port=500 to-address=192.168.88.113 to-address=500
add chain=dstnat action=dst-nat in-interface=<your WAN interface> protocol=udp dst-port=4500 to-address=192.168.88.113 to-address=4500
If you have a static WAN ip, you could add dst-address=<your WAN IP> to each line
ros code
add chain=forward action=accept protocol=udp dst-address=192.168.88.113 dst-address=500 in-interface=<your WAN interface>
add chain=forward action=accept protocol=udp dst-address=192.168.88.113 dst-address=4500 in-interface=<your WAN interface>
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
kneuzgi
Thu Mar 20, 2014 5:40 pm
If put in this:
add chain=dstnat action=dst-nat in-interface=ether1-gateway protocol=udp dst-port=500 to-address=192.168.88.113 to-address=500
add chain=dstnat action=dst-nat in-interface=ether1-gateway protocol=udp dst-port=4500 to-address=192.168.88.113 to-address=4500
then i'm getting following error/message:
expected end of command (line 1 column 113)
expected end of command (line 1 column 114)
Rudios
Forum Veteran
Forum Veteran
Fri Mar 21, 2014 12:29 am
My mistake. I wrote to-address twice. The second one in each line should be to-ports. Possibly it also could be to-adresses. I'm writing out of my head and not tested the commands for typo's
Users browsing this forum: No registered users and 39 guests
