Michal82
Auto connect to second provider
Tue May 20, 2014 9:51 am
Hi folks, i have one question, where i need help.
I have in input 2 internet providers - provider A is main internet, used 99% of time and provider B is backup internet connection. When i have connection A down, i must manually turn-off this connection in router router and turn-on connection B.
Question: How set it automatically? If connection A is OK, use it, if not, use connection B.
Thank you very much.
My Mikrotik CCR1016-12G
cdiedrich
Forum Veteran
Forum Veteran
Re: Auto connect to second provider
Tue May 20, 2014 10:27 am
Netwatch?
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
Michal82
Tue May 20, 2014 10:54 am
I understand principle, but how i can it write?
bingo220
Tue May 20, 2014 11:27 am
In the both interfaces uncheck "use-default-route"
next step:
simplest method http://wiki.mikrotik.com/wiki/Two_gateways_failover
the best method (for me) http://wiki.mikrotik.com/wiki/Advanced_ ... _Scripting
Michal82
Tue May 20, 2014 12:40 pm
A.) please, could you write me how do?
B.) I want use this metode, but i will need some helps: http://wiki.mikrotik.com/wiki/Advanced_ ... _Scripting
1.)
add dst-address=www.google.com gateway=GW1 scope=10
add dst-address=www.bing.com gateway=GW2 scope=10
2.)
add distance=1 gateway=www.google.com routing-mark=WAN1 check-gateway=ping
add distance=2 gateway=www.bing.com routing-mark=WAN1 check-gateway=ping
3.)
add distance=1 gateway=www.bing.com routing-mark=WAN2 check-gateway=ping
add distance=2 gateway=www.google.com routing-mark=WAN2 check-gateway=ping
I have it OK for my setting, or i can do some changes?
bingo220
Tue May 20, 2014 1:59 pm
Both my ISP use a PPPoE connections.
PPPoE automatically adds the default-route. Because of it I need to disable this (uncheck "use-default-route").
If your connections is not added the default-route, you can skip this step.
I suggest you start with a simple method http://wiki.mikrotik.com/wiki/Two_gateways_failover
In second method you have to use:
1) GW has to be ONLY IP.
2) You have to add static route for each ping-hosts by needed ISP.
etc.
Michal82
Tue May 20, 2014 2:16 pm
But i read that this simply metod is not reliable.
bingo220
Tue May 20, 2014 3:13 pm
Many people use it and do not complain :)
Just try it.
Ok, I'll try explain about second method.
Make sure that your internet-connections don't use "Add default route".
To avoid problems, use the public DNS on the router, like 8.8.8.8.
Choose four ping-hosts for check an internet accessibility (2 hosts for each ISP).
Those addresses will be available only through one of the ISPs.
While the router can ping at least one of the two hosts this route is enabled, otherwise, the route turns off.
My choice is four stable public NTP servers.
You can find here http://support.ntp.org/bin/view/Servers ... imeServers
For example:
1) 212.82.32.15
2) 198.153.152.52
3) 204.123.2.72
4) 209.81.9.7
Further, we have to use an ip-address in the GW of each ISP.
Suppose GW of my ISP1 = 101.x.x.1
and GW of my ISP2 = 202.x.x.2
Create static routes.
add dst-address=212.82.32.15 gateway=101.x.x.1 scope=10 comment="Static PING way by ISP1-host1"
add dst-address=198.153.152.52 gateway=101.x.x.1 scope=10 comment="Static PING way by ISP1-host2"
add dst-address=204.123.2.72 gateway=202.x.x.2 scope=10 comment="Static PING way by ISP2-host1"
add dst-address=209.81.9.7 gateway=202.x.x.2 scope=10 comment="Static PING way by ISP2-host2"
Create a virtual hops.
It has to be different of your LAN. Just invented addresses.
I use 10.10.1.1 and 10.10.2.2
add dst-address=10.10.1.1 gateway=212.82.32.15 scope=10 target-scope=10 check-gateway=ping distance=1 comment="Virtual host for ISP1-host1"
add dst-address=10.10.1.1 gateway=198.153.152.52 scope=10 target-scope=10 check-gateway=ping distance=2 comment="Virtual host for ISP1-host2"
add dst-address=10.10.2.2 gateway=204.123.2.72 scope=10 target-scope=10 check-gateway=ping distance=1 comment="Virtual host for ISP2-host1"
add dst-address=10.10.2.2 gateway=209.81.9.7 scope=10 target-scope=10 check-gateway=ping distance=2 comment="Virtual host for ISP2-host2"
Create default routes.
Route with distance=1 will be primary.
add distance=1 gateway=10.10.1.1 comment="Default route to WAN1"
add distance=2 gateway=10.10.2.2 comment="Default route to WAN2"
hossain2004a
Tue Jan 13, 2015 7:09 pm
It's good, but when pingnig from mikrotik tools i would have some "timeouts" beside other pings, why?
add dst-address=4.2.2.4 gateway=192.168.20.3 scope=10 comment="Static PING way by ISP1-host1"
add dst-address=4.2.2.5 gateway=192.168.20.3 scope=10 comment="Static PING way by ISP1-host2"
add dst-address=4.2.2.6 gateway=192.168.30.3 scope=10 comment="Static PING way by ISP2-host1"
add dst-address=4.2.2.8 gateway=192.168.30.3 scope=10 comment="Static PING way by ISP2-host2"
add dst-address=10.10.1.1 gateway=4.2.2.4 scope=10 target-scope=10 check-gateway=ping distance=1 comment="Virtual host for ISP1-host1"
add dst-address=10.10.1.1 gateway=4.2.2.5 scope=10 target-scope=10 check-gateway=ping distance=2 comment="Virtual host for ISP1-host2"
add dst-address=10.10.2.2 gateway=4.2.2.6 scope=10 target-scope=10 check-gateway=ping distance=1 comment="Virtual host for ISP2-host1"
add dst-address=10.10.2.2 gateway=4.2.2.8 scope=10 target-scope=10 check-gateway=ping distance=2 comment="Virtual host for ISP2-host2"
My DNS: 4.2.2.4 , 4.2.2.8
anything wrong bingo220?
bingo220
Tue Jan 13, 2015 10:18 pm
hossain2004a, I have no ping problem (just checked).
Try to use the other hosts.
I think public NTP servers are good choice.
Users browsing this forum: MITM and 15 guests
