Leudassdf
Implements Routing between 3 separate LANs
Fri May 23, 2014 5:06 pm
Hi Everyone,
I need to create 3 separate Lans. However, they must be able to communicate with each other.
To create the various Lans follow the following tutorial will: http://networkingforintegrators.com/201 ... -mikrotik/
At the moment I have the LAN1, LAN2 and LAN3 on port 2,3 and 4 respectively.
However i cant make LAN1 communicate with other LANs The same situation occurs in all other LANs
How do I implement routing between these LANs?
Thanks for all the help you can Provide to me and excuse any errors of Inglês.
cutedrummerboy
Re: Implements Routing between 3 separate LANs
Thu May 29, 2014 5:26 pm
hi, you have to set route in your router and in each network element. your router will be the gateway for each network. provide details configuration.
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
Users browsing this forum: No registered users and 30 guests
