gxmc
Problems Forwarding ports to use Steam
Tue Jun 03, 2014 2:11 pm
Steam's page says the following:
Steam Client
UDP 27000 to 27015 inclusive (Game client traffic)
UDP 27015 to 27030 inclusive (Typically Matchmaking and HLTV)
TCP 27014 to 27050 inclusive (Steam downloads)
UDP 4380
Then I did the following rules
14   chain=dstnat action=dst-nat to-addresses=192.168.75.10 protocol=udp
     dst-port=27000-27030
15   chain=dstnat action=dst-nat to-addresses=192.168.75.10 protocol=tcp
     dst-port=27014-27050
16   chain=dstnat action=dst-nat to-addresses=192.168.75.10 protocol=udp
     dst-port=4380
I tested them with the PortForward's PortChecker tool and everything is fine but the Steam stops logging in when the rule 14 is active. Its one of those 30 UDP ports, I dunno which one but I guess it doesn't matter. I need to know the reason the Steam stops working when I redirect the ports and the redirecting is working properly according to the testing tool.
rextended
Re: Problems Forwarding ports to use Steam
Tue Jun 03, 2014 5:47 pm
I use Steam for play ;)
The username on steam are the same as here... ;)
You do not need to open anything, do not do any, remove all your rule, are all wrong,
simply enable UPNP on Routerboard and configure it correctly ;)
This is my UPNP config, I never have one game that not work with that:
/ip upnp
set allow-disable-external-interface=no enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=MATRIX type=internal
add disabled=no interface=pppoe-client type=external
MATRIX must be your local ethernet / bridge
pppoe-client your internet source.
I'm Italian, not English. Sorry for my imperfect grammar.
Rudios
Forum Veteran
Forum Veteran
Tue Jun 03, 2014 8:40 pm
Steam Client
UDP 4380
     dst-port=4380
Add the dst-address or in-interface parameter to the rules, this could solve your issue.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
rextended
Tue Jun 03, 2014 8:41 pm
Have you Steam and using it?
Rudios
Forum Veteran
Forum Veteran
Tue Jun 03, 2014 8:48 pm
Honestly no but I assumed this is 'normal' natting.
With the rules given, all packets will be dst-natted, inbound and outbound. That's why I thought about specifying in-interface could help.
gxmc
Wed Jun 04, 2014 5:35 am
/ip upnp
/ip upnp interfaces
I know how to activate the UPnP and I actually use it, I disabled it in order to test something that involves the manual port opening.
gxmc
Wed Jun 04, 2014 5:46 am
And it did, indicating the in-interface solved the problem, thanks.
Can you manage to explain it to me? I don't understand why the Port Checker had no problems being reached by the outside and the Steam Client didn't.
Users browsing this forum: Google Adsense [Bot] and 43 guests
