MUM Europe 2020
leio
vlan clients are not getting dhcp addresses
Fri Jun 27, 2014 2:35 am
Hi ,
I have a problem with my RB2011UiAS-2HnD which I configured for a very basic vlan setup,
the clients connected to the ports for vlan 10 are not getting IP addresses thru DHCP.
Is this a bug ? the default firmware for the RB2011UiAS-2HnD I got was 6.12 and I started to see that issue there,
I upgraded to 6.15 but the same issue.
Here is my setup "Mikrotik RB2011UiAS-2HnD Vlan + DHCP server"
RouterOS firmware 6.15
Bios - 3.16
RB2011UiAS-2HND
+--------eth2(trunk vlan10)
+-------eth3(access vlan10) +--------- laptopA (dhcp) (not getting ip)
+------eth4(access vlan10) +--------- laptopB (dhcp) (not getting ip)
vlan10 = 192.168.10.1
pool = 192.168.10.111-192.168.10.254
eth2 - Master = none
eth3 - Master = eth2
eth4 - Master = eth2
Issue:
- Laptop Clients (eth3 and eth4) cannot get IP from dhcp server pointed to vlan10
- laptopA can ping laptopB when static IP is configured on both of them.
- Why I cannot ping vlan10 interface IP address too?
Below is my configuration , please let me know if I am missing something here. I just want to make this work first before I proceed with other plans on my list.
[admin@MikroTik] > export
# jan/02/1970 02:08:30 by RouterOS 6.15
# software id = IDQ7-U9MS
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
set [ find default-name=ether7 ] master-port=ether6
set [ find default-name=ether8 ] master-port=ether6
set [ find default-name=ether9 ] master-port=ether6
/interface wireless
set [ find default-name=wlan1 ] l2mtu=2290
/ip neighbor discovery
set ether1 comment=WAN
/interface vlan
add interface=ether2 l2mtu=1594 name=vlan10 vlan-id=10
set 2 default-vlan-id=10 vlan-header=add-if-missing vlan-mode=secure
set 3 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
add name=vlan10-dhcpsvrpool ranges=192.168.10.111-192.168.10.254
add address-pool=vlan10-dhcpsvrpool disabled=no interface=vlan10 name=vlan10-dhcpserver
/port
set 0 name=serial0
add independent-learning=no ports=ether3,ether2,ether4,switch1-cpu switch=switch1 vlan-id=10
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.1 netmask=24
/ip upnp
set allow-disable-external-interface=no
/lcd interface
set sfp1 interface=sfp1
set ether1 interface=ether1
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6 interface=ether6
set ether7 interface=ether7
set ether8 interface=ether8
set ether9 interface=ether9
set ether10 interface=ether10
set wlan1 interface=wlan1
/system logging
add topics=dhcp,debug
[admin@MikroTik] >
/leio
on4cet
Re: vlan clients are not getting dhcp addresses
Sat Jun 28, 2014 8:18 pm
Same here, checked everything, still not working. I upgraded from 6.6 to 6.15 and the dhcp issue appeared. Hoping for a fix !
leio
Mon Jul 07, 2014 8:59 pm
Hi I just want to update my post and I got the solution from the mikrotik support.
Here's their support answer :
Switch1-cpu port also should be a VLAN trunk like ether2, because it has DHCP
server on VLAN interface.
Try to set this command:
set switch1-cpu vlan-header=add-if-missing vlan-mode=secure
AlainCasault
Trainer
Trainer
Tue Nov 25, 2014 11:52 pm
Thanks for sharing leio! You just saved me a ton of grief :D
==EDIT==
Now, can't ping my WAN port (ether1).
Here's my config.
RB2011-----TRUNK-----RB750G (Pod3)----PC
# jan/01/2002 01:42:34 by RouterOS 6.22
# software id = E76V-SSW8
/interface vlan
add interface=ether2 l2mtu=1516 name=vlan1 vlan-id=1
add interface=ether2 l2mtu=1516 name=vlan2 vlan-id=2
set 1 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=2 vlan-header=always-strip vlan-mode=secure
set 4 vlan-header=add-if-missing vlan-mode=secure
set 5 vlan-header=add-if-missing vlan-mode=secure
add name=dhcp_pool1 ranges=172.26.3.2-172.26.3.254
add address-pool=dhcp_pool1 disabled=no interface=vlan2 lease-time=3d name=\
dhcp1
/system logging action
set 2 remember=yes
add ports=ether5,ether2,switch1-cpu switch=switch1 vlan-id=1
add ports=ether5,ether3,switch1-cpu switch=switch1 vlan-id=2
add address=172.26.3.1/24 interface=vlan2 network=172.26.3.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ether1
add address=172.26.3.0/24 dns-server=172.26.3.1 gateway=172.26.3.1
set allow-remote-requests=yes
/system identity
set name=Pod3
I have only the default route that my dhcp-client gets.
Internaly, I can ping all, even WAN on E1. From the RB2011, I can't ping the RB750G (Pod3).
If switch1-cpu is leave-as-is, all pings well but my PC can't get an IP address from local DHCP-server on Pod3.
Ideas anyone??
:shock:
___________________________
Alain Casault, Eng.
If I helped you, let me know!
sejtam
Sun Feb 08, 2015 8:50 am
did you ever find a proper solution?
I got the same when setting the switch-cpu interface to vlan-mode=secure/strip. Everything just stops
Users browsing this forum: No registered users and 25 guests
