MUM Europe 2020
aresmt
port 80 bloked issue - RB2011UiAS-2HnD-IN
Sat Aug 02, 2014 6:28 pm
HI,
I have 2 RB2011UiAS-2HnD-IN router.
One of it is in a remote location which i don't have physicaly access very easy ,only remote connection.
This one, has an strange behavior, or maybe i don't know how to use it.
From time to time it starts to block port 80 when i try to connect from his lan on internet. HTTPS and other ports and protocols are ok, but not 80.
If i reset it to defauld configuration and restore the last backup config, it start to works, but only for a while. (jusrt restart dosen't fix the problem)
It has basic routing config and 3 port forward rules.
The second one i use it in my apartamnet, never had this issue.
I recently upgrade it to the last version 6.17
Any advices? ideea? suggestions?
Thanks in advance,
marizo
Re: port 80 bloked issue - RB2011UiAS-2HnD-IN
Sat Aug 02, 2014 6:43 pm
Maybe UPnP is on and some local service trying to use it?
aresmt
Sat Aug 02, 2014 6:46 pm
Just checked, UPnP is not enabled.
plisken
Sat Aug 02, 2014 8:30 pm
What RouterOs?
Have you add firewall rules?
ParsagachkarDev
Sat Aug 02, 2014 11:05 pm
plz provide more info!
you mean blocked input 80 , forward 80 or both! (access to router with port 80 , access through router with that port or both)
are u using Firewall Rules ?????
/ip firewall filter print
/ip firewall nat print
aresmt
Sun Aug 03, 2014 12:38 am
What RouterOs?
3.18
no rules than default rules which come with the default config
thanks
aresmt
Sun Aug 03, 2014 12:45 am
What RouterOs?
3.18
thanks
sorry, it was 6.17, was specified in my first post.
Just upgraded to 6.18 now
plisken
Sun Aug 03, 2014 12:49 am
Post your export file in this forum then can we look what wrong if you can login.
aresmt
Sun Aug 03, 2014 12:56 am
even with 6.18 is the same
 root ~: ping forum.mikrotik.com
PING forum.mikrotik.com (159.148.147.201) 56(84) bytes of data.
64 bytes from tuncis.mt.lv (159.148.147.201): icmp_seq=1 ttl=57 time=71.8 ms
64 bytes from tuncis.mt.lv (159.148.147.201): icmp_seq=2 ttl=57 time=71.0 ms
64 bytes from tuncis.mt.lv (159.148.147.201): icmp_seq=3 ttl=57 time=71.4 ms
^C
--- forum.mikrotik.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2251ms
rtt min/avg/max/mdev = 71.069/71.463/71.899/0.459 ms
 root ~: telnet  forum.mikrotik.com 80
Trying 159.148.147.201...
^C
 root ~: telnet gmail.com 443
Trying 173.194.44.22...
Connected to gmail.com.
Escape character is '^]'.
telnet> quit
Connection closed.
 root ~: nslookup forum.mikrotik.com
Server:         192.168.10.110
Address:        192.168.10.110#53
Non-authoritative answer:
Address: 159.148.147.201
 root ~: telnet 8.8.8.8 53
Trying 8.8.8.8...
Connected to 8.8.8.8.
Connection closed by foreign host.
aresmt
Sun Aug 03, 2014 1:55 pm
doesn't that file contain users, passwords, and other sensitive info?
plisken
Sun Aug 03, 2014 2:14 pm
Sensitive data can't be readed.
aresmt
Sun Aug 03, 2014 3:19 pm
sorry, can't do that. don't know who decided what is sensitive or not for a specific user
i can post specific outputs if you give me the commands.
Thanks,
plisken
Mon Aug 04, 2014 10:18 am
Go to terminal.
Type: "export"
That's it
aresmt
Wed Aug 06, 2014 9:25 pm
Go to terminal.
Type: "export"
That's it
another issue that i have is that when i try to access from INSIDE the lan xyz.mydomain.com it doesn't work, only from outside my network is working. can you also take a look at the firewall rules with port forward for 80
here is the output :
# aug/06/2014 21:02:50 by RouterOS 6.18
# software id = AJNU-VQUA
add admin-mac=MAC:MAC:MAC:MAC:MAC auto-mac=no l2mtu=1598 name=bridge-local
set [ find default-name=ether1 ] mac-address=MAC:MAC:MAC:MAC:MAC name=ether1-gateway
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=ether10-slave-local
set [ find default-name=sfp1 ] name=sfp1-gateway
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors l2mtu=2290 mode=ap-bridge ssid=MySID wireless-protocol=802.11
/ip neighbor discovery
set ether1-gateway discover=no
set sfp1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=MySID-pass wpa2-pre-shared-key=MySID-pass
add name=dhcp ranges=192.168.10.10-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge-local lease-time=10m name=default
/port
set 0 name=serial0
/interface ovpn-client
add add-default-route=no auth=sha1 certificate=cert_2 cipher=blowfish128 connect-to=bla.bla.bla.com disabled=no mac-address=MAC:MAC:MAC:MAC:MAC max-mtu=1500 mode=ip name=\
    ovpn-to-dub password=hidden-pass port=10443 profile=default user=my-hidden-user
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=sfp1-gateway
add address=192.168.10.1/24 comment="default configuration" interface=ether2 network=192.168.10.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
add address=192.168.10.0/24 comment="default configuration" dns-server=192.168.10.1 gateway=192.168.10.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add chain=input dst-port=8080 in-interface=ether1-gateway protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=sfp1-gateway
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" out-interface=sfp1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-port=80 protocol=tcp to-addresses=192.168.10.125 to-ports=80
add action=dst-nat chain=dstnat dst-port=10443 protocol=tcp to-addresses=192.168.10.128 to-ports=10443
add action=dst-nat chain=dstnat dst-port=51413 protocol=tcp to-addresses=192.168.10.126 to-ports=51413
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set www port=8080
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set allow-disable-external-interface=no
/system clock
set time-zone-name=Europe/xxx
/system identity
set name=my-router-name
/system ntp client
set enabled=yes primary-ntp=ip.ip.ip.ip secondary-ntp=ip.ip.ip.ip
/system scheduler
add comment=DynDNS interval=5m name=DynDNS on-event=DynDNS policy=reboot,read,write,policy,test,password,sniff,sensitive start-time=startup
/system script
add name=DynDNS policy=reboot,read,write,policy,test,password,sniff,sensitive source=":global ddnsuser \"my_dyndns-user\"\
    \n:global ddnspass \"hidden-pass\"\
    \n:global theinterface \"ether1-gateway\"\
    \n:global ddnshost bla.bla.bla.com\
    \n:global ipddns [:resolve \$ddnshost];\
    \n:global ipfresh [ /ip address get [/ip address find interface=\$theinterface ] address ]\
    \n:if ([ :typeof \$ipfresh ] = nil ) do={\
    \n   :log info (\"DynDNS: No ip address on \$theinterface .\")\
    \n} else={\
    \n   :for i from=( [:len \$ipfresh] - 1) to=0 do={ \
    \n      :if ( [:pick \$ipfresh \$i] = \"/\") do={ \
    \n    :set ipfresh [:pick \$ipfresh 0 \$i];\
    \n      } \
    \n}\
    \n \
    \n:if (\$ipddns != \$ipfresh) do={\
    \n    :log info (\"DynDNS: IP-DynDNS = \$ipddns\")\
    \n    :log info (\"DynDNS: IP-Fresh = \$ipfresh\")\
    \n   :log info \"DynDNS: Update IP needed, Sending UPDATE...!\"\
    \n   :global str \"/nic/update\\\?hostname=\$ddnshost&myip=\$ipfresh&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG\"\
    \n   /tool fetch address=members.dyndns.org src-path=\$str mode=http user=\$ddnsuser \\\
    \n         password=\$ddnspass dst-path=(\"/DynDNS.\".\$ddnshost)\
    \n    :delay 1\
    \n    :global str [/file find name=\"DynDNS.\$ddnshost\"];\
    \n    /file remove \$str\
    \n    :global ipddns \$ipfresh\
    \n  :log info \"DynDNS: IP updated to \$ipfresh!\"\
    \n    } else={\
    \n     :log info \"DynDNS: dont need changes\";\
    \n    }\
    \n} \
    \n"
/tool mac-server
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=ether10-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
aresmt
Fri Aug 08, 2014 3:18 pm
any ideas guys?
joegoldman
Long time Member
Long time Member
Sat Aug 09, 2014 5:31 am
ros code
Pretty sure this rule - without defining an 'In' interface or dst-address, will be catching ALL your NAT port 80 attempts and trying to port forward you internally.
Remove this rule as a test and see if it helps.
aresmt
Sat Aug 09, 2014 1:13 pm
ros code
Thanks,
Is working now.
Can you also help me with the other issue please?
When i point my browser to my domain bla.example.com which has that port forwarding rule 192.168.10.125:80, i get an error message like "The page is not available."
But from internet the rule is working.
Thanks,
joegoldman
Long time Member
Long time Member
Sat Aug 09, 2014 3:08 pm
You will need Hairpin NAT, or in some cases I simply add the same domain as a static DNS if your using the Mikrotik as a DNS server for your LAN clients, and point it to the web server internally only.
http://wiki.mikrotik.com/wiki/Hairpin_NAT
Users browsing this forum: No registered users and 31 guests
