nereww
how to logging ntp server
Tue Aug 05, 2014 3:15 pm
Hi
i have instaled ntp package and i need to logging ntp server. can anyone help. standar logging does not work for this package.
thanks
jayd2k
Re: how to logging ntp server
Wed Aug 06, 2014 7:24 am
note from the documentation:
NOTE: the above logging rules work only with the built-in SNTP client, the separate NTP package doesn't have any logging facilities.
In regards to the sntp client take a look at the wiki:
Background on how to configure logging http://wiki.mikrotik.com/wiki/Manual:Sy ... figuration
Log messages explained -> http://wiki.mikrotik.com/wiki/Time#Log_messages
By 2016 total internet traffic will be 3x 2011
nereww
Thu Aug 07, 2014 3:08 pm
Hi
Yes, i saw this in documentation. So I nedd another option how to do it.
Rudios
Forum Veteran
Forum Veteran
Fri Aug 08, 2014 10:12 am
Hi
If you want to use the logging functions available on the S-NTP client, uninstall the NTP package.
Go to system -> packages, select the NTP, hit uninstall and reboot.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
rextended
Fri Aug 08, 2014 10:17 am
Hi
The use do not "want to use the logging functions available on the S-NTP client", want use NTP server and there is no way to logging it's operation.
I'm Italian, not English. Sorry for my imperfect grammar.
Users browsing this forum: ZacharyBeade, ZakPreston and 44 guests
