allansud
Mikrotik Rb750 DHCP SERVER PROBLEM
Tue Aug 19, 2014 11:53 pm
Hi all,
I have Mikrotik RB750, what i want to do is to set up the router from the bignning.
1) set the address in Ip->Address to WAN port 192.168.1.0/24
2) ether2 -> set as master port
3)ether3 -> slave
4)ether4-> slave
5)ether5 -> slave
6) Ip-> pool -> 192.168.2.0/24
7) Ip-> dhcp server -> set the pool and ether2-master
8) Ip->dhcp server -> tab networks -> address 192.168.1.0/24 -> gateway 192.168.1.1 -> DNS 192.168.1.1
PROBLEM:
DHCP server get red and no computer gets IP!! :(
Please guys help me...
rextended
Re: Mikrotik Rb750 DHCP SERVER PROBLEM
Tue Aug 19, 2014 11:57 pm
I'm Italian, not English. Sorry for my imperfect grammar.
allansud
Wed Aug 20, 2014 4:29 pm
Hi all,
I solve my problem yesterday. Thanks for the tips rextended.
In interface i was putting the wrong interface. The correct interface is ether2-master.
Thanks!
pateutz
Wed Aug 20, 2014 4:36 pm
how did you solved the issue ? Can write some clues ?
Best Regards
Rudios
Forum Veteran
Forum Veteran
Wed Aug 20, 2014 8:06 pm
Interface must have ip address in the range handled by the DHCP server
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
allansud
Wed Aug 20, 2014 9:03 pm
Exactly!!! That was part my mistake...
pateutz
Thu Aug 21, 2014 1:25 am
Hi all,
thanks i forgot to put the address on the interface. This solved me the first issue that i face it.
The second issue that still "colored red the secondary DHCP configuration" was because i forgot to remove the virtual interface from the bridge that already was part from primary DHCP configuration.
Anyway all you help was for me the success of my configuration .
Best Regards to all !
Users browsing this forum: No registered users and 35 guests
