overdream
SOS---After enabled hotspot, can't ping internal client
Thu Aug 21, 2014 1:39 pm
Outside Client: 192.168.0.10/23
Internal Client:192.168.88.10/24
Router ether1: 192.168.1.63
Router bridge1: 192.168.88.1
Routing table:
0.0.0.0/0 ether1
192.168.88.0/24 bridge1
192.168.0.0/23 ether1
without Hotspot
Ping 192.168.0.10 -> 192.168.88.10 OK
Ping 192.168.88.10 -> 192.168.0.10 OK
with Hotspot
Ping 192.168.0.10 -> 192.168.88.10 Not OK
Why I can't ping internal client 192.168.88.10 after enabled Hotspot, How to fix it?
Please Help. Thank you in advance.
overdream
Re: after enabled hotspot, outside can't ping internal clien
Thu Aug 21, 2014 1:44 pm
by the way, I try to tracert from 192.168.0.10 to 192.168.88.10
it stop at the 192.168.1.63(ether1)
and the export configuration file as attached
overdream
Re: SOS---After enabled hotspot, can't ping internal client
Mon Aug 25, 2014 9:42 am
is there anybody can help me?
Marconet
Mon Aug 25, 2014 10:59 am
it is normal hotspot gives dhcp you will only be able to see those ips given by the hotspot according to my experience you have to disable the hotspot for the time you want to ping clients or you ping using the ips delivered by the hotspot
overdream
Mon Aug 25, 2014 1:39 pm
you ping using the ips delivered by the hotspot, what's that means?
SurferTim
Mon Aug 25, 2014 4:13 pm
If I need to ping the clients on the hotspot interface, I found I must use a out-interface icmp masquerade on the hotspot interface.
add chain=src-nat action=masquerade protocol=icmp out-interface=ether2
If ether2 is not the hotspot interface, change that.
overdream
Tue Aug 26, 2014 8:01 am
I have to add all Hotspot interface(bridge interface) and wireless to NAT as you said. but it still doesn't work,
the 192.168.0.10 still can't ping 192.168.88.10, the system return "Destination host unreachable"
but it working for ping 192.168.88.1
SurferTim
Tue Aug 26, 2014 3:04 pm
You know the device using 192.168.88.10 must be logged in to ping it, right?
edit: Or you need to bypass that ip through the hotspot if it can't login.
/ip hotspot ip-binding
add address=192.168.88.10 type=bypassed
overdream
Wed Aug 27, 2014 5:05 am
Dear SurferTim,
It's working, Thank you vvvvery much.
Users browsing this forum: aritahl, Google [Bot], langeli, mszru and 93 guests
