Helios79
Speed limiting on torrents, P2P, and media streaming
Fri Sep 12, 2014 12:29 am
Howdy all,
Over the past couple of weeks, I have been fighting with getting some speed limitations up and going for WISP customers. Like any provider, we run into problems with people downloading torrents which saturates the Internet connection for everyone. I have tried quite a few QoS scripts that I have found online and they all fail to limit the speed.
I know that I can cure this problem with pfSense, but that isn't an option in this case. Is there a working script that works with 5.26? We cannot use 6.x due to problems with RADIUS authentication.
Thanks.
cliffborton
Re: Speed limiting on torrents, P2P, and media streaming
Mon Sep 15, 2014 9:55 am
First let me know that you want to drop all traffic to torrent or you want to limit the users to use from torrent ? If you want to Block or drop all traffic to the torrent you can use this rule , I use it and it's work correct my friend :
add action=drop chain=forward comment="Block torrentz Traffic" content=\
www.torrentz.com
Best Regards,
zulkamal
Tue Oct 07, 2014 7:55 am
http://www.torrentz.com
Best Regards,
Hi there...i'm also facing the same issue..
User download using torrent and make my traffic congest....can I block all the p2p download and at the same time I want to limit the download speed for all type of download?....please advice...thank you in advance...
skoenman
Tue Oct 07, 2014 11:17 pm
Hey guys i have also been having some issues with the people doing p2p connections and it is a problem. What i have found is the best way to mitigate this is to do the following
1. Mark connections you know the traffic of eg..http...ssh..email..
2. Mark the source ips of the guys detected to use p2p....limit there number of connections to 200 otherwise they going to limit your routerboards cpu very quickly.
3. Mark connections that use a certain amount of data and put under queue just for downloads. All connections over a certain connection amount gets marked as downloads.
What i have also found is if you have gamers you need to prioritise the ports aswell.
Big thing comes in when you have multiple lines and you need to do load balancing and qos on the same routerboard....
Hope it gives you a idea of what to do.
hipro5
Mon Oct 27, 2014 11:40 am
IF ALL clients are MikroTik based hardware, YES you CAN cut both of their download and upload speed.
IF they are NOT, you can EASILY "cut" ONLY their download speed at the speed you wish, through ACCESS LIST of your MicroTik AP.
ADD them all at the access list and go through it and change the download and upload limit to anyone of them.
This is the easiest way.
Other ways through scripts are possible and people in here will help you do so (I'm not familiar with it).
Users browsing this forum: No registered users and 23 guests
