MUM Europe 2020
Wiredup
Trouble connecting to router over PPTP
Sun Oct 26, 2014 5:22 am
Hoping someone can help me. I'm fairly new to using Mikrotik. I have a RB750GL at my home and I have another client of mine using a CRS109-8G-1S-2HnD-IN. I'm using this as a router on quick set as a "home AP". I upgraded the software to 6.20 and checked the quick VPN option. All is good at this site. I am able to connect successfully connect to the site and login into the router to make changes.
To I set up another client of mine with the same router set up using quick set and as a "home AP". I upgraded the software to 6.20 and set up the quick VPN. I am able to connect to the site successfully but I can not login into the router to do any changes to in. If I try the IP address of the router it never connects. I've tried to ping the router and it doesn't work.
Is there something simple I'm missing or is there something I can try to fix this.
Thank you in advance for any info.
Sent from my iPhone using Tapatalk
Wiredup
Re: Trouble connecting to router over PPTP
Tue Oct 28, 2014 12:26 am
Does anyone have any suggestions for this? Thank you!
gabrielpike
Tue Oct 28, 2014 5:22 pm
More information is needed to help troubleshoot you issue. I would suggest looking at differences in IP firewall filter settings first. I usually set up VPNs manually through PPP options.
Gabriel Pike
MTCNA
Users browsing this forum: No registered users and 66 guests
