hareth
ipsec
Sun Nov 02, 2014 7:46 pm
What is this
b1863515
Re: ipsec
Sun Nov 02, 2014 10:50 pm
I guess the "500" represents the number of the error.
Rudios
Forum Veteran
Forum Veteran
Re: ipsec
Mon Nov 03, 2014 12:13 pm
500 is the default port IPsec traffic is on.
I guess someone is trying to put a IPsec tunnel online.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
hareth
Re: ipsec
Tue Nov 04, 2014 6:53 pm
What is the solution to help me
jarda
Re: ipsec
Tue Nov 04, 2014 7:07 pm
Switch off ipsec and block unwanted communication by firewall.
lambert
Long time Member
Long time Member
Re: ipsec
Tue Nov 04, 2014 10:06 pm
First, tell us what the problem is.
Is the remote IP one of your VPN clients attempting to connect to the VPN server?
  • If so, they are failing to connect for some reason.
    1. Enable IPSec debugging.
    2. Find out what the error was.
If the remote IP is not one of your users attempting to make a VPN connection, you have two choices.
  1. Ignore the log entries when crackers fail to log in to your VPN server.
  2. Use firewall rules to block access to your VPN server from locations from which it is not likely for your users to connect.
Port 500 is used for IPSec IKE (phase1) connection setup.
hareth
Re: ipsec
Wed Dec 03, 2014 5:50 pm
tania
Re: ipsec
Sun Jan 11, 2015 10:37 am
hareth
Re: ipsec
Sat Jan 07, 2017 4:10 pm
hlooooooooooooooo!!!!!!!!!!!!!!
Users browsing this forum: MSN [Bot] and 31 guests
