MUM Europe 2020
qwertysqwerty
Two default routes - DAC, DS.
Sun Nov 02, 2014 9:00 pm
I have an error in my routing table. Let me explain my home set-up:
  • I use an ADSL/ADSL2+ modem. This modem is connected to ether1-gateway port of my [http://routerboard.com/]RB2011UiAS-2HnD-IN router.
  • My RB2011UiAS-2HnD-IN obtains a LAN IP from the DHCP server configured on the modem (192.168.2.0/24).
  • My RB2011UiAS-2HnD-IN uses the PPPoE client to obtain a WAN IP from my ISP via the ADSL/ADSL2+ modem.
The problem is that the RB2011* will end up with two default gateway addresses in the routing table after it has obtained the WAN IP from my ISP.
For example:
 0 ADS  0.0.0.0/0                          [ISP_REMOTE_IP]           1
 1  DS  0.0.0.0/0                          192.168.2.1               1
 3 ADC  [ISP_REMOTE_IP]/32 [MY_WAN_IP]     pppoe-out1                0
 4 ADC  192.168.2.0/24     192.168.2.10    ether1-gateway            0
 5 ADC  192.168.10.0/24    192.168.10.1    wlan1                     0
This is a problem because:
  • increased latency (?) / route duplication
  • the direct static (DS) default route is highlighted blue (in WinBox GUI) and I have no idea what this means
  • I have to remove this route manually each time my WAN IP changes
jarda
Re: Two default routes - DAC, DS.
Mon Nov 03, 2014 8:32 am
Blue lines are inactive so they have no influence on routing decision. Only active routes do.
Rudios
Forum Veteran
Forum Veteran
Mon Nov 03, 2014 8:59 am
For example:
You do not need a DCHP client address from your modem, I guess. I assume it is only needed for maintenance tasks on the modem.
Because you have a pppoe client I assume your modem is in bridge mode.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
qwertysqwerty
Mon Nov 03, 2014 7:31 pm
Ah I see. Good.
You do not need a DCHP client address from your modem... I assume it is only needed for maintenance tasks on the modem.
Yes, I do need it. For firmware updates, etc. It is useful to have this connectivity to the modem.
Yes. What value does this comment add?
Rudios
Forum Veteran
Forum Veteran
Tue Nov 04, 2014 10:24 am
Ah I see. Good.
If you need connection to your modem only for firmware upgrades, I would disable the DHCP client on the MikroTik and only enable it when communication to the modem is needed in any certain time.
Another solution would be to put a static IP address on the interface connected to the modem, this won't get you a default route.
Also disabling the "add default route" option on the DCHP client could be an option. Since the IP addresses of your modem and mikrotik are in the same segment, a router is not needed for communication to the modem.
jarda
Tue Nov 04, 2014 10:38 am
I have cable modem in transparent mode and mikrotik router with DHCP client on wan interface. When modem and router both start simultaneously the router is faster and asks for ip. As the modem is not linked yet to cable provider it provides local address by his own. When the link to operator goes up, it sends nak and router asks again. Now it gets public ip. As the modem still keeps his ip and it is from other subnet I use locally the default route routes all packets with modem destination ip to the wan and modem normally responds even the wan port has public ip yet. So no other rule for that is necessary.
Rudios
Forum Veteran
Forum Veteran
Tue Nov 04, 2014 3:09 pm
In my case, this works the same. I first get a 192.168.x.x address from the modem and when the link to ISP is online, my mikrotik gets my public IP (and looses it local 192.168.x.x address)
But since qwertysqwerty is using pppoe (ADSL) he has 2 dhcp-client running. (I assume)
Users browsing this forum: franklin44377 and 50 guests
