MUM Europe 2020
niktoin
basic setting for the AP
Wed Nov 12, 2014 12:47 pm
Hi Guys,
First at all I would like to tell that I am a newbie here and in the Mikrotik family at all.
I am using router 751U-2HnD as AP and have trouble with correct settings.
I have network with one domain controller (file system, DNS, DHCP). And would like to connect mikrotik as AP.
I had been useing winbox and set AP by quick setting tab. Settings working fine, just mikrotik start dustribute own address from own pool to the network. How can I set it corectlly please?
If you need provide more detailed information, just ask for it, thank very much,
Best regards,
Daniel
plisken
Re: basic setting for the AP
Wed Nov 12, 2014 2:06 pm
Have you start with default configuration?
Is the IP-pool 192.168.88.0/24...
niktoin
Wed Nov 12, 2014 2:11 pm
Yes, I have. And I would like to switched off this pool. AP has to provide server dhcp pool only.
Thank you for your interest.
plisken
Wed Nov 12, 2014 3:28 pm
Go to "new terminal" and type "export"
copy and paste this on this forum please
caution! remove passwords first
Then can we look what going on
niktoin
Wed Nov 12, 2014 3:47 pm
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 5.26 (c) 1999-2013 http://www.mikrotik.com/
[admin@BSC_Private] > export
# jan/15/2002 06:56:11 by RouterOS 5.26
# software id = SVFD-S7H2
add admin-mac=D4:CA:6D:53:39:B1 ageing-time=5m arp=enabled auto-mac=no \
disabled=no forward-delay=15s l2mtu=1600 max-message-age=20s mtu=1500 name=\
bridge-local priority=0x8000 protocol-mode=rstp transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=D4:CA:6D:53:39:B0 mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:53:39:B1 master-port=\
none mtu=1500 name=ether2-master-local speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:53:39:B2 master-port=\
ether2-master-local mtu=1500 name=ether3-slave-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:53:39:B3 master-port=\
ether2-master-local mtu=1500 name=ether4-slave-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:53:39:B4 master-port=\
ether2-master-local mtu=1500 name=ether5-slave-local speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=\
passthrough group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
management-protection=disabled management-protection-key="" mode=\
dynamic-keys name=default radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=\
XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none \
static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" \
static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=\
none static-sta-private-key="" static-transmit-key=key-0 \
supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates \
unicast-ciphers=aes-ccm wpa-pre-shared-key=********* wpa2-pre-shared-key=\
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 \
antenna-mode=ant-a area="" arp=enabled band=2ghz-b/g/n basic-rates-a/g=\
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=\
20/40mhz-ht-above compression=no country=no_country_set \
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 \
default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no \
disconnect-timeout=3s distance=indoors frame-lifetime=0 frequency=2412 \
frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no \
ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 \
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mc\
s-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,m\
cs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=\
0,1 hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
D4:CA:6D:53:39:B5 max-station-count=2007 mode=ap-bridge mtu=1500 \
multicast-helper=default name=wlan1 noise-floor-threshold=default \
nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" \
nv2-qos=default nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=\
100ms periodic-calibration=default periodic-calibration-interval=60 \
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
D4CA6D5339B5 rate-selection=advanced rate-set=default scan-list=default \
security-profile=default ssid=*********** station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
wireless-protocol=802.11 wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add address-pool=default-dhcp authoritative=after-2sec-delay bootp-support=\
static disabled=no interface=bridge-local lease-time=3d name=default
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=default \
use-encryption=default use-mpls=default use-vj-compression=default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
use-compression=default use-encryption=yes use-mpls=default \
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=no \
redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=ospf-in \
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto \
metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] addresses="" authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \
name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password="" \
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
permissions=owner signup-allowed=no time-zone=-00:00
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web\
,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pass\
word,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,wi\
nbox,password,web,sniff,sensitive,api" skin=default
/interface bridge filter
add action=drop chain=input disabled=no dst-port=68 in-interface=ether1-gateway \
ip-protocol=udp mac-protocol=ip
add bridge=bridge-local disabled=no edge=auto external-fdb=auto horizon=none \
interface=ether2-master-local path-cost=10 point-to-point=auto priority=\
0x80
interface=wlan1 path-cost=10 point-to-point=auto priority=0x80
interface=ether1-gateway path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set 0 vlan-header=leave-as-is vlan-mode=fallback
set 1 vlan-header=leave-as-is vlan-mode=fallback
set 2 vlan-header=leave-as-is vlan-mode=fallback
set 3 vlan-header=leave-as-is vlan-mode=fallback
set 4 vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:73:D0:C5:1D:32 \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=\
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.115.10.6/24 comment="default configuration" disabled=no \
interface=wlan1 network=10.115.10.0
/ip dhcp-client
add add-default-route=yes comment="default configuration" \
default-route-distance=1 disabled=no interface=bridge-local use-peer-dns=\
yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=4096 servers=""
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=forward comment="default configuration" \
connection-state=established disabled=no
connection-state=related disabled=no
add action=drop chain=forward comment="default configuration" connection-state=\
invalid disabled=no
add action=masquerade chain=srcnat comment="default configuration" disabled=yes \
out-interface=ether1-gateway
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1-gateway disabled=no
set ether2-master-local disabled=no
set ether3-slave-local disabled=no
set ether4-slave-local disabled=no
set ether5-slave-local disabled=no
set wlan1 disabled=yes
set bridge-local disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=\
15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-gateway queue=only-hardware-queue
set ether2-master-local queue=only-hardware-queue
set ether3-slave-local queue=only-hardware-queue
set ether4-slave-local queue=only-hardware-queue
set ether5-slave-local queue=only-hardware-queue
set wlan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing pim
set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
trap-target="" trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system gps
set channel=0 enabled=no set-system-time=no
/system identity
set name=BSC_Private
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge-local disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether5-slave-local disabled=yes display-time=5s
set ether4-slave-local disabled=yes display-time=5s
set ether3-slave-local disabled=yes display-time=5s
set ether2-master-local disabled=yes display-time=5s
set ether1-gateway disabled=yes display-time=5s
/system leds
set 0 disabled=no interface=wlan1 leds=wlan-led type=wireless-status
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system ntp server
set broadcast=no broadcast-addresses="" enabled=no manycast=yes multicast=no
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
400MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol="" \
filter-mac-address="" filter-mac-protocol="" filter-port="" filter-stream=\
yes interface=all memory-limit=100KiB memory-scroll=yes only-headers=no \
streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
Big thanks, would like to help you as well
gabrielpike
Wed Nov 12, 2014 4:55 pm
I think what you are trying to do is easier than the default config is allowing. First I would remove default config. Then just add all ports to bridge. Next add LAN IP address to the bridge interface. Finally add static default gateway. Basically like this:
add name=LAN
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="united states" \
disabled=no frequency-mode=superchannel l2mtu=1600 mode=ap-bridge \
radio-name=Mikrotik ssid=Example tx-power=17 tx-power-mode=all-rates-fixed \
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed mode=dynamic-keys name=default-encryption \
supplicant-identity="" wpa-pre-shared-key=example wpa2-pre-shared-key=\
example
add bridge=LAN interface=wlan1
add bridge=LAN interface=ether2
add bridge=LAN interface=ether3
add bridge=LAN interface=ether4
add bridge=LAN interface=ether5
add bridge=LAN interface=ether1
add address=192.168.0.4/24 interface=LAN network=192.168.0.0
set allow-remote-requests=yes servers=8.8.8.8
add distance=1 gateway=192.168.0.1
/ip upnp
set allow-disable-external-interface=no
/snmp
set trap-community=public
/system identity
set name=LAN_AP
In this example the IP address of the AP is 192.168.0.4 and the IP address of the gateway is 192.168.0.1
Gabriel Pike
MTCNA
plisken
Wed Nov 12, 2014 6:55 pm
Please update first to the latest RouterOs
Then take again export and paste this here on this forum.
Why do I ask this.
Because changes have been made in the command line
niktoin
Thu Nov 13, 2014 12:18 pm
Why do I ask this.
MikroTik RouterOS 6.22 (c) 1999-2014 http://www.mikrotik.com/
p[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
jan/02/1970 00:00:53 system,error,critical router was rebooted without proper shut
down
[admin@MikroTik] > export
# jan/02/1970 00:11:07 by RouterOS 6.22
add admin-mac=D4:CA:6D:53:39:B1 auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
ether5-slave-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors l2mtu=1600 mode=ap-bridge ssid=BSC_Private \
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa-psk mode=dynamic-keys \
wpa-pre-shared-key=*********** wpa2-pre-shared-key=*********
add name=dhcp ranges=0.0.0.1-255.255.255.254
add address-pool=dhcp disabled=no interface=ether2-master-local name=default
set 2 remember=yes
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add action=drop chain=input dst-port=68 in-interface=ether1-gateway \
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether1-gateway
add address=192.168.88.1/24 comment="default configuration" disabled=yes \
interface=ether2-master-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
add comment="default configuration" dns-server=192.168.88.1 gateway=0.0.0.0
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
use master instead (bridge-local)
add action=drop chain=input comment="default configuration" in-interface=\
ether1-gateway
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" \
/ip upnp
/snmp
/system lcd
/system lcd page
/system leds
set 0 interface=wlan1
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
add interface=wlan1
/tool user-manager database
set db-path=user-manager
[admin@MikroTik] >
Big Thanks
kristaps
Thu Nov 13, 2014 12:21 pm
and what exactly doesn't work now ?
niktoin
Thu Nov 13, 2014 12:35 pm
When I set same settings on 5.26 OS,then mikrotik had distributed his own pool to the network.
plisken
Thu Nov 13, 2014 1:30 pm
@Niktoin: is your problem solved?
niktoin
Thu Nov 13, 2014 1:59 pm
I am not sure about it, let me check it, it takes couple of hours.
Users browsing this forum: kokkinakis, nickerpick, Pierre75, Sob and 52 guests
