golber
Internet with PPPoE on Eth10 port (instead of Eth1)
Thu Nov 27, 2014 6:03 pm
I need to use Eth10 port as an Internet input PPPoE.
If I use Eth1, PPPoE correctly connects.
In INTERFACE section of RouterOS, If I change PPPoE interface from Eth1 to Eth10, connection remains pending.
Can someone help me?
Bye
plisken
Re: Internet with PPPoE on Eth10 port (instead of Eth1)
Fri Nov 28, 2014 8:53 am
Have you ether10 in switch modus?
You must set his masterport to none
Doubleclick on interface ether10
See attachment (the red dot)
tsombeng
Fri Nov 28, 2014 8:56 am
Make sure that Eth10 is not a slave of any other port(it should be a master port)
golber
Fri Nov 28, 2014 9:58 am
Thanks!
I had to remove slaving from port 10 (and also remove bridge).
Now it's ok!
Bye
Users browsing this forum: gazingbazooka and 72 guests
