MUM Europe 2020
david6feo
ospf
Sun Dec 07, 2014 8:02 pm
I have a network of 6 routers, RB750 & RB2011 connected together using OSPF.
It seems to work well.
The two routers connecting me to the internet seem to need a NAT rule with a chain of SRCNAT and an action of MASQUERADE to work, the others don't.
Is this correct? or should I have the NAT rule on every router?
regards,
David.
Rudios
Forum Veteran
Forum Veteran
Re: ospf
Mon Dec 08, 2014 9:29 pm
It sounds correct to me, since your public IP address is assumably assinged to the ISP connected routers.
I assume you are using private IP ranges in your internal network. These IP's are not routed over the internet and outgoing traffic needs to be source-NAT'ed in order to go over the internet.
Ps. Masquerade is a special type of source-NAT'ing
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
Trackboy
Re: ospf
Tue Dec 09, 2014 3:14 pm
You need to NAT only on your router, that is connected to the ISP.
jfvelamoscoso
Trainer
Trainer
Re: ospf
Tue Dec 09, 2014 6:53 pm
You only have to nat on the border router (router connected to isp). Because you are using ospf and it is full implemented, you should not need nat on all the devices behind, because BR knows how too reach the other devices. I really don't like masquerade because you really don't know what is happening there. Try with chain=srcnat action=srcnat src-address=x.x.x.x/x to-addresses=ip which will replace the other ips. You can also add out-interface in order to be more especific.
jfvelamoscoso@gmail.com
Network Engineer Noc Department
MTCNA, MTCTCE
If it helps please give some karma
Users browsing this forum: Bing [Bot] and 36 guests
