kimmy123
Connect a Tenda Router to a ROS v5
Sun Dec 14, 2014 2:49 pm
Hi Guys
I have a wireless router from Tenda (W309R) that connects to a RB on ether3
I would like the RB to give the devices IP addresses instead of the Tenda itself.
I disabled DHCP on the Tenda.
On the WAN side for the Tenda has the option of DHCP ( which I selected) , static IP,PPTP and L2TP.
Please let me know if I will be able to do this.
Kimmy
SystemErrorMessage
Re: Connect a Tenda Router to a ROS v5
Sun Dec 14, 2014 4:55 pm
I think you are doing this the wrong way. You should either bridge the WAN on the tenda if you only have 1 port or connect using a LAN port. Are you trying to prevent the clients communicating with the RB directly or not? The questions that are asjed recently all seem to be getting poorly structured
kimmy123
Sun Dec 14, 2014 5:06 pm
I apologise for not asking it clearly.
What I want is for my Tenda to act like a Layer 2 device and the RB to issue IPs via DHCP.
Please explain how I would bridge the WAN ?
kimmy123
Sun Dec 14, 2014 5:25 pm
screen shot from my Tenda WAN options.
Bonz123
Sun Dec 14, 2014 6:13 pm
just turn off dhcp server http://www.microcentertech.com/tech_cen ... 00241B.htm
and ip adresses it start's take from mikrotik.
bingo220
Sun Dec 14, 2014 7:15 pm
I think you need to disable DHCP-server on the Tenda LAN-setup. Then setup Tenda LAN ip-address as dhcp-client. Next step - connect Mikrotik-ether3 to LAN-port of Tenda.
I'll repeat again, don't use the WAN port of Tenda. Use LAN-port.
kimmy123
Sun Dec 14, 2014 7:58 pm
Thank you guys
Turning off dhcp and connecting to Lan port sorted out the issue.
Thanks again.
Users browsing this forum: No registered users and 37 guests
