JRayfield
SFP Module in CRS226-24G-2S+RM
Wed Dec 24, 2014 11:32 pm
I've got a couple of CRS226-24G-2S+RM Routers/Switches with which I'm trying to use MikroTik S-85DLC05D Transceivers.
According to the documentation, these should work in the SFP+1 cages.
I can install Mikro-Tik S-85DLC03D Transceivers in these two routers, in the SFP+1 cages, connect a short cable between these two 10Gb transceivers, and the two routers link up just fine.
But, if I try the same thing with the 1.25Gb transceivers, I can't get a reliable link between the two routers.
Has anyone else had any trouble in getting 1.25Gb SFP transceivers to work in the SFP+1 port on the CRS226-24G-2S+RM router?
John Rayfield, Jr.
SegwayDude
Re: SFP Module in CRS226-24G-2S+RM
Tue Jan 20, 2015 2:23 am
John,
I have found the same issues.
Did anybody have an answer to this ?
Stefan
scampbell
Trainer
Trainer
Tue Jan 20, 2015 3:00 am
FYI.....
From the brochure : First port supports 1.25G/10G modules, second port only 10G modules.
http://i.mt.lv/routerboard/files/CRS226 ... 094424.pdf
I hope this helps....
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
Users browsing this forum: No registered users and 36 guests
