MUM Europe 2020
yakuphan
Can i block or drop hotspot clients if not login
Sun Dec 28, 2014 5:04 pm
Hi, i want drop hotspot clients from host list if not login to 5 minute. Cause they are use my network for file transfer without login. How can i block this event.
Thanks for help !
imrankosi
Re: Can i block or drop hotspot clients if not login
Thu Jan 08, 2015 4:36 pm
use firewall to block such connections
sejtam
Fri Jan 09, 2015 5:52 pm
What would such a firewall rule look like?
Am I understanding the issue correctly, this is about clients connecting to the hotspot interface
but not logging in, yet being able to talk to other non-logged-in hotspot users
directly on that interface/bridge?
would (assuming the hotspot is on interface=ether2 with IP range 192.168.100.x-y and the web on 192.168.100.1
work?
add in-interface=ether2 address=!192.168.100.1 action=drop
ie: on that interface, drop all packets that do not involve the hotspot login webpage's IP address?
What about non-IP traffic (ethernet)?
Is there a way to record (and remember/blacklist) macaddresses of such clients (like in a macaddress-list ?) That would be useful
hossain2004a
Wed Jan 14, 2015 11:48 am
Thanks for help !
How they use your network traffic when you have hotspot server?
Is it possible? unless you opened ports 139 and 445
Users browsing this forum: MSN [Bot] and 32 guests
