Zwodka
Simple Queue for 2 subnet
Tue Jan 06, 2015 11:05 am
Hi All!
I get to know the Simple Queue topic. I use a Rb951G for internet sharing:
- 10M up / 20M down
- 2 subnet
First of all I would like to share the bandwidth evenly distribute.I tried this:
add dst=ether1-gtw max-limit=10M/20M name=Sq-Lan1-Lan2 priority=8/8 queue=default/default target=192.168.81.0/24,192.168.82.0/24
But I would like to provide higher priority for first subnet:
add dst=ether1-gtw name=Sq-Lan1 parent=Sq-Lan1-Lan2 priority=7/7 target=192.168.81.0/24
add dst=ether1-gtw name=Sq-Lan2 parent=Sq-Lan1-Lan2 priority=8/8 target=192.168.82.0/24
Is it a right way to do it?
ngnr
Re: Simple Queue for 2 subnet
Tue Jan 06, 2015 12:09 pm
If you simply give higher priority to one of the targets you can end up with your 192.168.81.0/24 using all your bandwidth leaving your other subnet without any. The way I would prioritize is by defining 2 simple queues one for each target subnet. Allow max-limit 10M/20M on both queues so both subnets can have maximum speeds when not used. And last define limit-at parameters for each subnet. This will tell the mikrotik how to split the capacity in case of saturation. For examble you can set limit-at for 192.168.81.0/24 at 8M/16M and for 192.168.82.0/24 at 2M/4M. This way in case clients are using all the available bandwidth MKT knows how to split it.
Hope it helps.
Zwodka
Tue Jan 06, 2015 2:07 pm
Hope it helps.
It sounds good!
MegaThanx!
Users browsing this forum: No registered users and 18 guests
